Engine failure. Options?
Old Sep 21, 2019 | 03:03 AM
Eric B's Avatar
Default Engine failure. Options?
My KLX 250(with a 351 kit) suffered a rather catastrophic engine failure. I'm taking the engine apart, when I get time, to figure out why. The head is good, but the cylinder & crankcase are toast.
I really enjoy this bike, for the riding I do, so I'm pondering options.
- Buy a used engine, or complete bottom end? There are a few on ebay. This seems to have a bit of risk. Questions come to mind - Why is someone selling a used engine or bottom end ?
- buy another whole bike. There are a few fair deals on CL.
- If I buy another bike, what to do with my engineless bike? Do they have value as a plated CA roller? Part it out?
Any thoughts or opinions are welcome.
Old Sep 21, 2019 | 12:15 PM
Tacoma660's Avatar
id try a ebay motor and transfer the top end from your over to it or have a mechanic go through the whole engine first to make sure its good
Tacoma660's Avatar
im going on 5000 miles with my 351, knock on wood trouble free
Old Sep 23, 2019 | 06:29 PM
Eric B's Avatar
Originally Posted by Kwak
You can try to repair 351 cylinder.
I had a problem with my 351 cylinder, Bill installed new sleeve and bored it to fit old piston. The price was about the half of new 351 kit.
My cylinder & liner is not repairable, Kwak. I do have a spare 250 & 300 cylinder however.
Old Sep 23, 2019 | 09:12 PM
GBAUTO's Avatar
What happened to the bottom end that prevents repair/reuse? Unless you had a rod punch through the casting, I think that Bill may be able to still replace the sleeve and piston,
Old Sep 23, 2019 | 11:27 PM
Eric B's Avatar
That's what happened. The rod broke, and took out the cylinder & crankcase.
Still doing an autopsy, disassembling the engine, and trying to figure out what went wrong. Had oil, had water, piston did not seize.
Old Oct 29, 2019 | 03:25 AM
Eric B's Avatar
Follow up - I purchased a 4000 mile engine(2007 model). Pulled the head & cylinder, to see if it was truly 4k miles, and not . . say 24k. All looked good. I had to use the '09 stator(different connectors) & nuetral swich, and put in new rings. Finally got it installed and it fired right up. I like the brown clutch & ignition covers that came on the earlier KLX. Cannot wait to be on my KLX again, I missed it.
canklx
Jul 13, 2017 02:03 AM
Ruggybuggy
Mar 20, 2016 11:46 PM
trail Joe
Jan 31, 2011 04:42 PM
bweekley
May 2, 2010 01:22 PM
scottma978
Aug 13, 2009 02:47 AM
