Endu-Cross modification
Old Mar 22, 2013 | 04:57 PM
sorips85's Avatar
Default Endu-Cross modification
For enduro and light motocross use.
Modifications
ECU: de-restrict
Exhaust: handmade, no catalytic converter, same diameter as head pipe (o2 sensor cheat with two small resistances), remove air suction system, a resistance cheats sensor too.
Sparkplug: ngk cr9eix iridium (excellent idle).
Front sprocket: 13t JT.
Rear sprocket: 44t JT, (with this combination there’s no need for longer chain).
Intake: remove air filter cover, air temperature sensor cheat with a small resistance (always -5 Celsius).
Rear tire: metzeler mc5 +side screws (helps on mud hillsides).
Front tire: re-grooved dunlop d605 (until it melts).
Weight reduction: removed anything unnecessary like headlight, lcd speedometer, rear seat bag, turn signals, metal and plastic parts, wires etc. Approximately save 22 kg. (not bad!).
Sub frame: just cut it…
More mods in near feature (like suspension, electric starter remove, may be a 300cc kit with a versys 650 injector etc).
Spyros from Greece
My English isn’t very good but I’ll try to answer any question.
Thanx!
Old Mar 22, 2013 | 05:33 PM
DustyCowboy's Avatar
Originally Posted by sorips85
[FONT="Book Antiqua"]
How many miles on your chain before putting the 44t?
Illking's Avatar
i would put a bash plate and bark busters on that mods list. Could almost fool someone its a kx250f without the headlight
Old Mar 22, 2013 | 11:00 PM
sorips85's Avatar
12000km ~ 7500miles
modification continues
any new ideas welcome
Old Mar 22, 2013 | 11:08 PM
MaximusPrime's Avatar
Wow, 44 kilos. That thing is almost as light as a 2 stroke!
Nice work!
Old Mar 23, 2013 | 12:37 AM
ol'klx-er's Avatar
22 kilos; 44.+ lbs.
Old Mar 23, 2013 | 12:47 AM
Doh, I was converting the numbers but not units of measure.
22 kilos; 44.+ lbs. - Yeah I knew that, really. Really, I was a chem minor, we only dealt in metric.
Old Mar 23, 2013 | 12:55 AM
Thanx!
Your english looks fine to me.
Pictures are worth a thousand words.
Nice bike Spyros!
Dan
Old Mar 23, 2013 | 03:22 AM
grahamgower's Avatar
[/FONT][/QUOTE]
I like the new look Spyros. Tell me more about the sensor cheats. Is that to get richer EFI mix?
Old Mar 23, 2013 | 12:49 PM
sorips85's Avatar
[/FONT]
I like the new look Spyros. Tell me more about the sensor cheats. Is that to get richer EFI mix?[/QUOTE]
Yes, with a 3.3Kohm resistor in air temperature sensor the mixture enriched a lot.
May be FI ligth turns on.
Worst Consumption
Better Performance
and two 220ohm resistors for the O2 sensor.
Also thermostat removed for better coolant circulation.
EMS_0525
Oct 8, 2007 02:50 PM
LearjetMinako
Sep 8, 2007 02:14 AM
alarmman15613
Dec 30, 2006 07:26 AM
Vasmel22
Jun 20, 2006 07:02 AM
Violet_Vixen
Mar 30, 2005 03:48 AM
