Dyno Chart Listing
  #31
Old 08-21-2016, 07:58 AM
Klxster's Avatar
Reducing the MAJ orifice size is tuning the AF toward richness in the emulsion tube - therefore richer AFR at all main fueling circuit ops. Problem I had was that there was no info - that I could find - on what the tuning method should be. I know the tuning method for enriching the AF with progressively larger main jets. And as far as I can tell, the end results would be identical - so I went with what is known, larger main jets until AFR is charted(proven) to be correct.
  #32
Old 08-21-2016, 10:50 PM
Richard Avatar's Avatar
OK, I'll see if my a/f is drifting one way or the other as rpms climb and go from there.
Compounding the end result is the fact that cranking it open at mid to low rpm-which removes the needle taper effects (since it's now at one position/WOT) vs opening throttle more and more kind of places all the work load on the main jet. Meaning what's too rich at less than WOT may be perfect at high rpm,
- One tuner's article suggests removing the main jet altogether for testing, saying the bike should run cleanly up to about 3/4 throttle as you open it progressively (if the needle position is correct) before the lack of a mj has it stumbling.
Klxster
05-22-2015 10:49 PM
Klxster
01-28-2015 03:57 AM
Klxster
06-28-2014 02:32 AM
batcave
08-29-2013 07:37 PM
Klxster
07-31-2013 11:10 AM
Quick Reply: Dyno Chart Listing
