dumb jetting question
Old Mar 4, 2015 | 10:26 PM
Subasaki's Avatar
Default dumb jetting question
i searched....my question....is "drilling the slide" as the stage 2 dynojet kits suggests and drilling the "starter jet" .018 the same thing or 2 entirely seperate drillings? dont laugh plz
Old Mar 4, 2015 | 10:47 PM
ol'klx-er's Avatar
Two separate things.
Drilling the starter jet is the "Choke" (enricher jet) which helps the cold starting.
Drilling the slide lets the vacuum lift the slide faster. Twisting the throttle doesn't lift the slide in the stock carb.
ha ha ha.
just kidding.
Two separate things. Starter jet is the non-removable enrichment jet in the carb. Drilling it to 0.018" helps starting on those hart-to-start bikes. Dynojet instruction don't address this.
Drilling the slide is enlarging the vacuum hole in the plastic slider for somewhat increased throttle response.
Old Mar 4, 2015 | 11:11 PM
Subasaki's Avatar
ok good! lol..if anyone has a pic pointing out the 2..i will buy you a beer
Old Mar 4, 2015 | 11:29 PM
Of my choice?
See starter jet.
See slide lift hole
http://www.dynojet.com/pdf/2206.pdf
Old Mar 8, 2015 | 09:50 PM
marcham's Avatar
I don't think the current DJ kits require drilling anything...
Old Mar 8, 2015 | 10:09 PM
Frampton's Avatar
it doesn't. but making the choke(starter) jet larger helps with cold starting and starting when the bike has been sitting around for a few weeks.
Old Mar 9, 2015 | 07:55 AM
Klxster's Avatar
Wow, the DJ kit does not speak of drilling anything but the cap over the fuel screw..
Marcham, your carb setup and MCM should start instantly warm and within 720 degrees cold, with choke on - almost instantly..
Old Mar 9, 2015 | 03:56 PM
Some may still select the #2206 DJ kit listed for the KLX300. I think it makes sense for those going big bore. The needle is a bit more aggressive than the KLX250 DJ kits. The instructions include drilling the slider vacuum vent hold a little larger and drilling the fuel screw cap for removal. See part DD32 in the dynojet link above.
klx250scott
Jan 27, 2009 12:05 PM
TheMaverick
Mar 11, 2007 08:25 AM
bryantjt
Aug 30, 2006 03:09 PM
jared
Ninja 250R
Jul 30, 2006 12:40 AM
littledevil
May 8, 2006 09:14 PM
