Doing a 351
Old Jan 13, 2011 | 03:11 PM
trail Joe's Avatar
Default Doing a 351
I am just about to order a 351 kit from Bill Blue, is there anything tricky about the job? Or is it pretty straight forward? Thanks
Old Jan 13, 2011 | 07:25 PM
CousinLarry's Avatar
It's straight forward. Remove old cylinder and piston, replace with new.
Done.
Should take you 15-30 minutes.
Old Jan 13, 2011 | 07:59 PM
thejackcutts's Avatar
yeeeeeeaaaaaa, but you also have to re-jet it.
Old Jan 13, 2011 | 09:10 PM
That depends on your skill level.
The kit does not come with instructions , you use the manual. Have you looked at the installation threads here on KF? If not use the search and look at how others have gone about it.
It's not hard, but you need to have the manual, the right tools, some patience, and you need to keep everything clean and organized. It was my first time digging into an engine, I took it slow, did all the above suggestions, and even posted pics for guys like you. Mine came out great.
One important thing is when you think you have it all put back together right, turn it over at least four times with a socket wrench before you try starting it with the E-start.
Dan
Old Jan 13, 2011 | 09:59 PM
Blackheart58's Avatar
If you can follow instructions, and are careful not to drop anything down into the abyss of doom (the engine case), it's not difficult. The wrist pin retaining clips were the hardest thing for me. Timing is extremely important, but, that's just following directions. You must have an accurate, appropriate sized torque wrench, and know how to use it....again...follow instructions.
Old Jan 13, 2011 | 10:37 PM
trail Joe's Avatar
A have tried searching for 351 installation & can't find the thread about it. Does someone have a link?
Old Jan 13, 2011 | 10:39 PM
trail Joe's Avatar
So Blackheart, do you still have your KLR 650?
Old Jan 14, 2011 | 12:09 AM
Yep...I doubt I'll get rid of it until the day I quit riding!
Here's one thread for the 351 install: https://www.kawasakiforums.com/forum...ght=armycopter
Old Jan 14, 2011 | 12:10 AM
daveg's Avatar
when you put the cylinder at top dead center- take a picture of the cams- it will help at re assy time.
Old Jan 14, 2011 | 03:16 PM
trail Joe's Avatar
Thanks for the link Blackheart. That helps just seeing what is waiting for me.
Dave, good idea on the pic idea, i will take lots of them!
