DIY jet kit installs?
Old Jun 2, 2010 | 01:40 AM
09klx's Avatar
Default DIY jet kit installs?
Does anyone know where i can find a DIY jet kit install? Im having a really hard time to take the carb out.
Old Jun 2, 2010 | 01:58 AM
HeavyFuel's Avatar
Keep trying! I ended up pulling the intake boot (between the carb and airbox), and also moved the rear brake reservoir down out of the way.
Old Jun 2, 2010 | 02:18 AM
RaceGass's Avatar
Pinch the air box rubber boot, when the boot pulls away from the carb flange twist the carb side ways (intake bell left airbox side bell right when looking straight down at it) & remove straight up. It does take practice...
Old Jun 2, 2010 | 02:22 AM
GaryC's Avatar
Stickys are there to look up good info that others have already done.
Look here:
https://www.kawasakiforums.com/forum...ead.php?t=8886
which links to here:
http://hmfracing.com/forums/showthread.php?t=1617
Old Jun 2, 2010 | 02:28 AM
09klx's Avatar
The left carb screw was easy to take off, but the right one is rounded off..Any other way to take it off?
Old Jun 2, 2010 | 11:03 PM
GaryC's Avatar
if you mean the float bowl screws, try a pair of small or needle nose vice grips to crack it loose.
Old Jun 3, 2010 | 01:17 AM
3L4NS1R's Avatar
Yeah, I remember I had real issues getting the last screw off - pliers and a real strong wrist gets it off... and remember to get a new screw to replace the burred one!
Old Jun 3, 2010 | 08:07 PM
09klx's Avatar
I installed a new tip and i still couldn't take it off, its too tight!
Old Jun 3, 2010 | 08:21 PM
3L4NS1R's Avatar
Unscrew it like a drum head - loosen them all first, and in a star pattern, as in do one corner, then the opposite, then another corner and then it's opposite...
If you do all the screws up again, and do it that way, you might be able to get it off..
Pauls2ndblessing
Dec 22, 2012 02:13 PM
djchan
Aug 4, 2012 03:08 AM
Illking
Jan 24, 2011 11:34 PM
bootmud
May 22, 2010 02:38 AM
JazZ023
Aug 19, 2006 12:38 AM
