Diffrence between 250 & 300 header
Old May 21, 2010 | 06:07 AM
flymike's Avatar
Default Diffrence between 250 & 300 header
Im having sum dificulty finding a cheep klx300 header for my klx250, found one but the guy isnt sure what its off, Id like to know what the diffrence is in the pipes, the OD on mine is 32mm (1-1/4),as far as i know its the standerd item. Its a new zealand/ australian model, if thats any help
Thanks
Mike
Old May 21, 2010 | 10:45 AM
WestOzKLX's Avatar
If the bike IS an AUS/NZ model then the header is already a KLX300R part.
Old May 21, 2010 | 12:02 PM
flymike's Avatar
Thats what im trying to know for sure WestOzKLX. As far as I know it was brought new in NZ. But you never know. anyone got the OD mesurement of there stock header????
Old May 21, 2010 | 12:31 PM
WestOzKLX's Avatar
Just had a rough measure for ya. It's about 42 mm internal diameter. Mine is KLX300R for sure.
Old May 21, 2010 | 12:37 PM
WestOzKLX's Avatar
Old May 21, 2010 | 04:15 PM
jxg's Avatar
jxg
i can get you a measurement when I get home in a couple of hours. i have stock of each sitting on a shelf at home.
Old May 21, 2010 | 10:03 PM
zomby woof's Avatar
That's it.
The only difference is the end, which (300) accepts 1 1/2" pipe with the fiber 'donut'.
Old May 22, 2010 | 10:08 AM
flymike's Avatar
Thanks guys, sumtimes the simplest things can be hard to find out. Iv found a 300 header im going to use with my 300 pipe. Cheers
kyrral
Jan 22, 2011 03:35 AM
TrailCruiser
Feb 22, 2009 06:34 PM
WestOzKLX
Oct 9, 2008 02:05 AM
buffalony
Oct 6, 2008 08:16 PM
xyz1000rr
Dec 10, 2007 05:13 AM
