Difficult to start after accidentally stale
Hi everyone,
I’m having a very specific and frustrating issue with my 2009 Kawasaki KLX250S and I could use some insight.
If I accidentally stall the bike under load (clutch stall accidentally at a trafiic light), and try to restart it immediately, it refuses to fire up.
Here are the exact symptoms:
Has anyone experienced this on a fuel-injected KLX or similar dual-sport?
Any help to fix this would be highly appreciated. Thanks!
PS. i have this issue from day 1(bought it used before 10 years or so)
- The starter motor cranks completely fine and fast. It does not sound weak or bogged down at all, but the engine just won't fire.
- This lockout lasts for about 10 seconds. If I just sit there and wait it out for 10 seconds, it will then fire up quite ok.
- It is NOT a hot-start issue: If I shut the bike down normally using the key or the kill-switch—no matter how hot the engine is—it restarts instantly. This happens exclusively after an abrupt clutch stall.
- Turning the key OFF and back ON to prime the fuel pump during this 10-second window does not bypass the issue; it still requires the full wait time.
- Full open thottle does not work either.
Often times when the bike stalls the cylinder may still be full of exhaust and requires some time for it to "air out". I had that trouble with my SR500 if I stalled, but with it I could hold the manual compression release and kick it through several times to clear the cylinder.
I don't know if it will work, but you could turn the throttle full open, not pumping, but wide open, and crank the bike a few times to try to clear the cylinder. Then try the normal starting procedure again.
I should ask if your bike cranks over a lot to get started when cold. If so, and it is a carbureted bike the jetting is lean You can use a Dyno Jet kit or do Kawasaki parts (what my brother and I did) to get the right jetting. Here is a web site with the information
Israel-klx250s
Mar 4, 2012 08:33 AM
