Data logging a stock 2024 KLX300.
Old Feb 12, 2026 | 06:11 PM
  #61
Klxster's Avatar
If you gain the ability to view all internal tables, and make changes to them, I/we can unleash this engine for any mod combo.
Old Feb 12, 2026 | 06:22 PM
  #62
tsc's Avatar
tsc
Originally Posted by Klxster
@Olsen29 , I'm trying to figure out if you've simply come into some info about the structure of the ECM programming OR if you are about to be able to reprogram the tables and flash the changes back to the ECM.... ?
Do you understand that your post indicates a blended EFI solution (Uses Speed Density for low performance ops, AND Alpha-N for high performance ops ) and, therefore, explains the need for 8 "fuel maps" ?
Service manual for EFI bikes explicitly mention speed density mode for low load and alpha-n mode for high load. 8 maps however is the new discovery. But the "neutral" map explain "clutch switch" mode.
Old Feb 12, 2026 | 08:51 PM
  #63
Olsen29's Avatar
I can only say it is closer than it has ever been.
And there is this
https://oldskulltuning.com/kawasaki-...00-ecu-tuning/
But I don't recommend it at this time.
Old Feb 14, 2026 | 07:58 PM
  #64
Klxster's Avatar
That "oldskulltuning" site and their products are NOT able to read from, and flash to, the ECM.
So, there's no solution from them.
Had no idea the service manual described the algorithmic basis of the EFI solution. That is very surprising to me as most would have no idea what that's all about..
So, being verified as a blended solution, the reprogramming for performance could be limited to the alpha-n side if closed loop and speed density occupy the exact same operational envelope.
Old Feb 25, 2026 | 11:42 AM
  #65
Olsen29's Avatar
Default Latest progress in display of stock fuel
Google sheets dashboard
Parsed data in each gear group with cell counts and AFR error for each cell.
Old May 2, 2026 | 08:42 PM
  #66
Olsen29's Avatar
Default I t w o r k s ! !
26 tables defined, read, edited, written and verified!
Results
https://docs.google.com/spreadsheets...f=true&sd=true
I will wait for Dyno time to edit fuel. This log and analysis is adding about 4 degrees mid range and removing the retard at 7500.
Still rich over 7000 rpm. And 75% TPS.
Klxster
May 30, 2026 09:51 AM
Tim
KLX300R
Jul 15, 2016 08:45 AM
Oldad
Feb 19, 2015 05:51 PM
mustang
May 2, 2007 02:19 AM
mmatz
KLX300R
Apr 12, 2007 06:58 PM
