Dare I start a suspension thread....
Old Jan 31, 2014 | 10:06 PM
NorCalKLX's Avatar
Generally whats involved with doing the valves in the front end? The valves are a given, I'm sure you get new oil, anything else?
Old Feb 1, 2014 | 04:45 AM
GBAUTO's Avatar
There are plenty of threads on how to do this-it's pretty straight forward with the right tools. I didn't replace my seals because they only had a couple of k's on them-just new oil and the valve kit.
Old Feb 1, 2014 | 08:46 AM
Originally Posted by TNC
Mark, knowing you, you'd buy the parts and do it yourself. It's not hard. You can get the Race Tech Gold Valve kits from various vendors and John at Moto Pro supplies excellent kits too.
Sounds good. I was thinking some machining required beyond my very limited equipped garage.
Old Feb 1, 2014 | 04:16 PM
TNC made a special tool out of a bicycle seat post for the job.
https://www.kawasakiforums.com/forum...irflyer-40415/
Old Feb 1, 2014 | 06:48 PM
I wish you hadn't posted that, Scott. It makes feel almost as cheap as dan888.
Old Feb 1, 2014 | 06:56 PM
Some things just have to be done.
Old Feb 1, 2014 | 11:22 PM
Wow! shots fired.
Don't worry TNC anybody that rolls around with a fancy Moto-motorhome like you got is not cheap. (Driving 600 miles to save a couple hundred dollars on it might be though. )
Oh and it's
Thrifty,,,,,,,,,,,I think we decided the term was thrifty.
Old Feb 2, 2014 | 12:31 AM
  #28
linkin5's Avatar
Some of the best advice I've read here so far is to make your changes one at a time, that is great advice no matter if your jetting the carb, tweeking the suspension or adding mods as it gives you a lot of information if you pay attention to what the bike is telling you. How many times have you read a thread and the guy goes " I went up on the pilot and down on the slide, back to two rounds out, put the snorkel back in and I don't know now if I'm lean or rich", guess what we don't either.
Old Feb 3, 2014 | 02:14 AM
  #29
RaceGass's Avatar
Something for the off road enthusiast.
90 91 Kawasaki KX 250 Forks Front Forks Front End Brakes Clamps | eBay
http://www.ebay.com/itm/93-92-KAWASA...71386925570%26
Old Feb 3, 2014 | 04:02 AM
  #30
NorCalKLX's Avatar
So I compared the sag on my 3600 mile Kawi to my buddies bran new Kawi with less then 100 miles on it and it's the same. I thought for sure my bike settled out but I guess not.
What's the rule of thumb for dampening adjustment? I want to soften the rear compression so I would stiffen the rebound correct? I imagine if you allow the spring to compress more then the rebound will unwind more hence increasing the rebound adjustment...? Also is it one for one or any rule of thumb to get it close?
