Cylinder Head Cover Removal
Old Apr 24, 2014 | 06:28 AM
oldgypsy's Avatar
Question Cylinder Head Cover Removal
From page 5-15 of the Service Manual: Cylinder Head Cover Removal
Remove: Fuel Tank (see Fuel Tank Removal in the Fuel System chapter) Vacuum Switch Valve (see Vacuum Switch Valve Removal)
Heat Guard [A]
Cylinder Head Cover Bolts [B]
Has anyone had to remove the Vacuum Switch Valve in order to remove the Cylinder Head (Valve) Cover?
I didn't, but then I didn't use the Service Manual for guidance.
Old Apr 24, 2014 | 10:31 AM
The Vacuum switch is the smog crap that burns unburnt gasses. If you bike is used its probably been removed.
Old Apr 24, 2014 | 08:46 PM
hounderd's Avatar
You don't have to remove the vaccum switch valve to remove the cylinder head. You just need to disconnect it from where it connects to the head (right above the exhaust port). As stated above, its part of the smog system, so unless you live in CA its probably been removed already.
Old Apr 25, 2014 | 01:39 AM
oldgypsy's Avatar
I did buy the bike used. Originally titled in Alabama. It only had 550 miles on it, and I doubt the original owner removed it. Maybe it didn't come with the air valve control valve?
Old Apr 25, 2014 | 03:05 AM
GBAUTO's Avatar
Should be for the California spec bike-it's part of the evap system. The fed. spec bikes don't have them.
Old Apr 25, 2014 | 03:17 AM
ol'klx-er's Avatar
Sounds as though it's a 49 states bike, so not much in the way of anti-smog stuff.
mikey113
Oct 12, 2024 02:54 AM
thekeeper199
Oct 26, 2014 01:07 AM
higgs
Jun 1, 2012 10:37 PM
RaceGass
Apr 22, 2010 03:55 AM
shox rox ice
Feb 8, 2008 12:33 PM
