CS nut
Old Jun 11, 2012 | 05:56 PM
rgoers's Avatar
Originally Posted by djchan
Rgoers - the chain was in really poor repair. Not salvageable by a long shot. That stocker (inherited from the PO) was 5 years and 11K miles old. It didn't owe me anything.
And, my personal limit for dirtbike bling is a nice gold chain.
I understand.
Old Oct 6, 2012 | 10:29 PM
go cytocis's Avatar
Just replaced my chain & sprockets with new. *I know that the CS nut is VERY tight from the factory. *I used to think that they were being over-tightened when assembled but I have now had the nut off several times and it seems like each time, it is just as difficult to get off as the first time. *I am torquing to 70 ft/lb as specified in the manual. *
It seems like it is tightening as it's being ridden, or perhaps seizing. *There did appear to be a little corrosion between the nut, washer,and sprocket.
I applied some anti-seize compound this time so I'll see if that helps.
Any of you guys who regularly swap out your front sprocket find the same?
Typographical errors by*iPhone
Old Oct 6, 2012 | 11:28 PM
Malves's Avatar
First time I had to take it to a shop to use an impact gun. Now, my 18" breaker bar takes care of the job.
On the '09, the manual calls for 92ft-lbs.
Old Oct 6, 2012 | 11:51 PM
Yes, it does seem to be tight every time. Not as much as the first time, but I have technique down now. Anti-seize makes sense. I used a little transmission fluid on it.
Old Oct 7, 2012 | 01:49 PM
durielk's Avatar
I was going to put the 13 on myself... impossible. I took it to the shop & had it done... he said came off easy.... total BS.
Old Oct 7, 2012 | 02:48 PM
go cytocis's Avatar
@Malves: you are right , 92ft/lbs is correct, excuse my typo.
Regardless, my torque wrench goes to 140 ft/lbs and I can not loosen the CS nut with it. I use a 3' breaker bar!
Old Oct 7, 2012 | 03:01 PM
ahnh666's Avatar
life of me, could not do it with a breaker bar and jumping on it...impact gun took it off with no problem...
Old Oct 7, 2012 | 08:08 PM
djchan's Avatar
Mine stymied my rattle gun as well. Had to use a 2' breaker bar and literally stand on it. I was hoping it wouldn't be as bad in the future.
Old Oct 8, 2012 | 05:31 PM
ahnh666's Avatar
originally, it didn't work with the impact gun...but, twisting the impact gun as i pulled the trigger did the trick....now, it come off and on with ease when i switch back and forth between the 13t and 15t front....
Old Oct 8, 2012 | 08:49 PM
go cytocis's Avatar
@666: how often do you swap? ie. is it often enough that there is insufficient time for the surfaces to seize?
