Countershaft Sprocket Clunk Noise
Old Feb 12, 2015 | 01:21 PM
neonarc's Avatar
Originally Posted by GBAUTO
Doesn't look horrible from what I can see. If the teeth show any signs of hooking or if the valleys where the rollers contact are getting oblong rather round then it's time for replacement. Try pulling the chain away from the back of the rear sprocket-if it moves more than 50% of the depth of the tooth then the chain also needs to be replaced.
Tried the pull test, could only get just barely get a 1/4 of a tooth to show. The front looks just a tad hooked I think. I think I will replace it soon, but at least it's not an emergency issue. Thanks,
Old Feb 12, 2015 | 01:25 PM
neonarc's Avatar
Originally Posted by marcham
On the 1st picture it looks like the top cog about to engage the chain is missing. Is this a 15 cog with the original chain length and rear sprocket?
Yeah it does jaja, but there all there, 14 of them anyway as came stock. At least that's what I understand from the service manual and this page.
JT Sprockets: Catalogue
Thanks,
Old Feb 12, 2015 | 09:01 PM
That front sprocket is JUNK! Dump it. Per my thinking it also looks like the rear has a fair amount of wear. It isn't easy to see with a picture though. It just looks like the U profile is worn out of symmetry. The rear will always hook at a slower rate due to having the chain supported by more teeth than the front, distributing the load and thus the wear is lower.
I think someone put a new chain on old sprockets based on the "pull test" for chain wear. Keep running those sprockets and you will ruin the chain due to the irregular loading on the chain due to the worn sprockets. That was what the PO of my bike did. I commented about the worn sprockets and he didn't think they were. I replaced them immediately. He also put on a really cheap non-O-ring chain, which I would not have done and didn't do. I did new sprockets and a new DID O-ring chain.
Old Feb 13, 2015 | 12:21 AM
Brewster's Avatar
Both sprockets are worn. Replace them and the chain.
Ride on
Brewster
dan151
May 13, 2012 12:33 AM
redpillar
Nov 2, 2008 05:03 AM
Bulls90
May 10, 2007 12:27 AM
jjm525
Ninja 500R
Oct 2, 2006 11:58 PM
