cooked my catalytic converter?
Old Dec 15, 2016 | 05:51 PM
peabrain's Avatar
the cam chain tensioner was replaced with a manual one this summer
i have since checked it by both trying to tighten and with it a bit more loose no change apart from chain rattle when loose
both had no effect on the noise
sorry but it is hard to film a sound when it is only during load and with warm engine
Old Dec 15, 2016 | 05:57 PM
Ruggybuggy's Avatar
Maybe a friend or the wife could video while you ride?
Old Dec 15, 2016 | 05:59 PM
peabrain's Avatar
sorry none aviable and wind would also drown out the noise since it is high pitched
Old Dec 15, 2016 | 06:02 PM
peabrain's Avatar
this weekend i am going to re check my valves just to rull that out
Old Dec 16, 2016 | 02:57 AM
durielk's Avatar
Since the scraping noise is only while your riding, I don't think it could possibly be the valves. They are going to sound the same regardless of load or no load.
I would say it is something from the clutch on back to the rear wheel.
Since u are lid less & after u install a loud muffler, it will be fixed automatically!
Old Dec 18, 2016 | 10:45 AM
peabrain's Avatar
just checked my valves
FL 0.15-0.20 FR 0.1-0.15 (FR is draging to point the 0.15 gauge is bendind if not supported)
RL 0.1-0.13 RR 0.1-.013 (0.15 did not fit)
i think i am gonna change the exhaust to the upper end of the scale and not shure if i wanna touch the inlet
did notice that the Air Suction valve System when i pinch the hose goin i half the airbox noise disaperes (maybe this warrents giving it a cork )
i will reshim valves first weekend in jan since i have hand surgery this wendnes day and can take the bike apart before new year and order shims for the first weekend next year
and be ready to install them plus my new exhaust
Old Dec 18, 2016 | 06:07 PM
GBAUTO's Avatar
It's possible that you're hearing the steel reed valves vibrating at certain engine speeds. A simple block off plate will eliminate that as a source.
Old Dec 18, 2016 | 06:13 PM
peabrain's Avatar
only happens (to my hearing) when the engine is warmed up.
does a block off plate kit exist that will make it look like it is still "working" ?
Old Dec 18, 2016 | 06:32 PM
peabrain's Avatar
i wonder if threading where the hose goes on the valve and blocking with a bolt will sufice?
zaheerZX6R
Jan 8, 2013 08:49 AM
zaheerZX6R
Jan 2, 2013 05:40 AM
bmwhd
Jun 8, 2011 07:08 AM
horizonod
Dec 20, 2008 12:44 AM
