Compression/Damping Adjustment Guidance Pleeeease !
I see were the owners manual gives the stock adjustment as 'x' number of clicks out, but it DOESN'T say what direction of screwing does what. Adjustments:
Front Compression
Rear Compression
Rear Rebound
Tell me what way does what !
All shock and fork dampeneing adjustments on all motorcycles ('m not aware of any exceptions) are right hand threaded needle valves. That means if you turn in clockwise (in), it will close the valve and increase the amount of damening by restricting oil flow as the piston moves giving more control and firmer ride. If you open the valve, turn CCW (out) it will reduce the dampening and provide less control or a softer ride.
As a general rule, you want as little dampening as possible to maintain control and prevent bottoming out of the suspension. Remember the springs d oall teh work, the shock just controls how quickly it's allowed to move and prevent bouncing.
Ever riddne in a older Jeep? That's what happenes if you have almost no dampening on you motorcycle... you bounce. Ever seen a hardtail harley? it has no rear suspension... that's what happens if you have wayy too much dampening, nothing moves. The adjusters only allow a small range of adjustment between those two extremes.
Thanks, that is an extremely interesting topic for sure.
How would you adjust the rear spring height on the shock? Is there a standard for that? I have it adjusted the spin rings up (obout 1/4 down on the threads) just so that my short legs aren't so far off the ground when I sit on it. I was thinking of increasing the compression a click or two to make up for this 'softer' setting.
I am VERY inclined to mechanical things, 25+ years of wrenching experience. But I WILL admit this dirt bike suspension issue is still confusing me a bit....I appreciate your time in explaining.
Here's a link that might help with the sag adjustment. But remember the spring should not be adjusted for your height. It should be adjusted for the proper sag (3 1/2" -4 "). You could use lowering links if needed.
Try this: http://www.planetklx.com/techtips/sag.shtml
ORIGINAL: sullydirt
I used the kouba links and they work great, they come in three different sizes.I use to be on my tippy toes but now I am almost flat footed. they were $80 bucks shipped to my door. go to www. Koubalinks.com
