Clutch Safety Switch Replacement
Old Jun 14, 2017 | 04:01 PM
Rock Hugger's Avatar
Originally Posted by Anthony LaGrasta
I want to be able to start in gear, with the clutch lever pulled in. As it stands, the bike must be in neutral, regardless of clutch lever position. Before and after replacing the switch, noting changed.
You're making my point. Replacing the switch on the clutch lever changes nothing to do with the neutral safety switch.
Old Jun 14, 2017 | 04:12 PM
LaGrasta's Avatar
I did break my clutch switch, thus needing a new one. I expected this was my problem. Why must I be in neutral to start the bike? Any guess to what my problem might be?
LaGrasta's Avatar
i thought the clutch switch is the neutral safety switch.
Old Jun 14, 2017 | 07:17 PM
klxnoobie's Avatar
It is if clutch switch isn't bypassed bike can only start when it's in neutral or clutch lever is pulled in which closes the switch. Sidestand switch kills the engine if you attempt to put in gear with sidestand down.
Old Jun 14, 2017 | 07:52 PM
LaGrasta's Avatar
Originally Posted by klxnoobie
if clutch switch isn't bypassed, bike can only start when it's in neutral or clutch lever is pulled in
yes, we're on the same page. I'd like it to work exactly as it's supposed to, as you explained, however mine does not. Mine will not start unless in neutral, regardless of pulled in lever.
Forget about kickstand, i understand how this works and it is functioning correct. When testing, kickstand is up.
Old Jun 15, 2017 | 12:24 AM
Abramsgunner's Avatar
Mine does the same... I can reach up with my right hand and jiggle the switch a little while the clutch is pulled and she'll turn over in gear. I may file a little off of the switch nub as I don't think it is extending far enough with the clutch pulled to complete the circuit..
Edit: Hey, now that I think about it.. I'm pretty sure mine is a Motion Pro clutch lever and it may not be quite to OEM spec. I can't remember if it would start in gear before I replaced the lever.
Old Jun 15, 2017 | 08:58 PM
LaGrasta's Avatar
I now am more confused than ever, after reading this.
Video: Jay Clark Honda CRF450RX Tech Tip - Dirt Bikes
I guess mine never worked correctly. My problem is, and always has been; I must be in neutral to start the bike, clutch lever has no effect at all. What to do?
Old Jul 3, 2017 | 06:16 PM
LaGrasta's Avatar
FIXED
It tuned out, my aftermarket break-away levers didn't open the switch enough to activate it. A simple lever adjustment and now it works as intended. The bike will start in gear as long as the clutch is pulled in, perfect.
zklx250
May 27, 2016 08:33 PM
Casper137
Mar 6, 2015 08:42 PM
outerextreme
May 22, 2008 03:22 PM
Dragon
Jun 7, 2007 02:40 AM
bryantjt
Feb 15, 2007 05:32 AM
