Clutch lever pivot
Old Oct 31, 2017 | 07:37 PM
Sam Thompson's Avatar
Default Clutch lever pivot
hey guys and gaps,
so my clutch lever ever seems to be very wobbly on it's verticals axis. I believe the clutch lever pivot is broken. The bike still functions normally. I just want to be able to have the bike in proper condition. let me know if anyone has replaced this or has an easy fix.
thanks,
sam
Old Nov 1, 2017 | 01:39 AM
GBAUTO's Avatar
I would remove the lever from the perch and inspect the bolt and bushing in the lever for wear.
Old Nov 1, 2017 | 11:59 AM
Kwak's Avatar
I had the same problem, found that bushing in the clutch lever was worn out. Replaced new lever and vertical movement disappeared.
Old Nov 1, 2017 | 12:38 PM
Levers are cheap as are whole perch/lever assemblies. I don't get too shook up over some wobble. That much less likely to break if I tip over on a trail. Both my 650 and 250 have some play in the levers.
klx-vn
May 16, 2016 11:53 PM
neilapples
Jan 10, 2011 12:30 AM
8cuttlefish8
May 24, 2009 11:52 AM
MaverickAus
Apr 29, 2008 12:27 AM
mr2turbo
Mar 18, 2006 08:16 AM
