Clutch lever pivot
hey guys and gaps,
so my clutch lever ever seems to be very wobbly on it's verticals axis. I believe the clutch lever pivot is broken. The bike still functions normally. I just want to be able to have the bike in proper condition. let me know if anyone has replaced this or has an easy fix. thanks, sam |
I would remove the lever from the perch and inspect the bolt and bushing in the lever for wear.
I had the same problem, found that bushing in the clutch lever was worn out. Replaced new lever and vertical movement disappeared.
Levers are cheap as are whole perch/lever assemblies. I don't get too shook up over some wobble. That much less likely to break if I tip over on a trail. Both my 650 and 250 have some play in the levers.
