clutch
Old 05-10-2014, 10:34 AM
Frampton's Avatar
Default clutch
my clutch is starting to slip when changing gears hard, in high gears and even somtimes when i let off the throttle. should i get a new oem clutch? or are there some better aftermarket ones with some stronger springs maybe?
thanks!
Old 05-10-2014, 10:05 PM
Richard Avatar's Avatar
EBC clutch plates with Barnett springs seem to be the recommended replacement IIRC (don't use the EBC springs)
Old 05-10-2014, 11:09 PM
RockabillSlapMatt's Avatar
have you adjusted the free play?
Old 05-11-2014, 03:25 AM
Frampton's Avatar
yes i have adjusted the free play but i have also noticed that there is some slop where the cable connects on the side of the bike, is this supposed to be there?
Old 05-13-2014, 01:32 PM
Rapa's Avatar
What's the problem with ebc springs? I'm using it... I always felt that the clutch is too hard....
Should I buy the Barnett springs?
Old 05-13-2014, 02:57 PM
EBC springs are too soft, almost softer than stock when I received them. If you don't do the big bore kit don't worry about it.
Old 05-13-2014, 03:57 PM
Frampton's Avatar
How about the springs that come with ebc drc kit? They are supposed to be 15% stronger
Old 05-13-2014, 04:38 PM
Those are the same springs. Barnett springs are stronger.
Old 05-13-2014, 08:44 PM
taxonomy's Avatar
Some years ago EBC had a bad batch of springs. They looked OK but the springs were not heat treated or some such. The springs wound up being too soft and compressing very quickly.
It's pretty well documented that this happened. Since then EBC had not had problems with their springs.
This being said I just installed the EBC clutch with springs and it does seem pretty feather weight to me. I'll probably wind up switching them out for Barnett. If I had this to do angain I would have probably used KX125 frictions and a single KLX250s friction to accommodate the judda spring. More area, OEM quality. Should hold fine with stock springs.
Here's my write up on clutch options for the 250s https://www.kawasakiforums.com/forum...h-notes-41905/
jcbowling1985
Ninja 250R
10-19-2012 05:35 PM
RayCour
07-21-2010 10:35 PM
deej
10-02-2008 09:58 PM
JERSEY
04-23-2006 08:30 AM
Quick Reply: clutch
