That was close
Old May 28, 2019 | 06:06 PM
  #31
peabrain's Avatar
The best part of the MCM mod is that it is free
Old May 28, 2019 | 08:01 PM
  #32
Klxster's Avatar
a;lskdjfpoqiweuprqioaejds;zxcnv,m
Old Jun 7, 2019 | 03:06 PM
  #33
jhampshire's Avatar
From: Illinois. It was a nice place when I moved here 40 years ago.
Default Cam balance
Originally Posted by Dominic Caselli
Might that cause an imbalance that wipes out your bearings? The piece that was there had to be balanced. Cutting it off without any way of knowing how it's going to react seems risky. I know it's small, but it's job is to spin like crazy...
I had the same question. Here is my opinion.
If anything was going to throw the cam out of balance it would be the lobes which are both pointing the same direction for obvious reasons. The bearing surfaces are very large in order to carry the intense load of compressing valve springs. So I think the minor imbalance from removing the KACR is not an issue.
The best way to wipe out cam bearing surfaces is to run out of oil or fail to change out dirty oil. Another way is to habitually rev the motor after a cold (dry) start. Next best way is to over tighten a manual cam chain tensioner or to mess with the automatic adjuster. Otherwise I would not worry about it.
sixgun
KLR250
Jun 8, 2017 03:04 AM
timc63
Sep 10, 2015 06:39 PM
Byrdjo
Jan 25, 2015 11:30 AM
McRider
Jun 20, 2014 02:08 AM
mikecashless@msn.com
Classic Sportbikes
Nov 6, 2007 01:51 AM
