Clarke Tank with Unabiker rad guards.
Old Nov 17, 2007 | 12:50 AM
stellar_d's Avatar
Default Clarke Tank with Unabiker rad guards.
Anyone running both? I might have to buy a new tank, and may as well get a big one. Just want to make sure it fits with those unabiker rad guards.
Old Nov 17, 2007 | 04:20 PM
Sid Post's Avatar
Default RE: Clarke Tank with Unabiker rad guards.
I'm going to find out if I ever get a day off work that finds me at home. Radiator guards are installed and the Clarke tank is sitting in the cellophane wrap ...
Seems like I read somewhere that they are compatible with a minor modification to the radiator guards.
Old Nov 17, 2007 | 06:20 PM
stellar_d's Avatar
cool keep me posted....oh I got the guards btw thank you
Old Nov 17, 2007 | 08:19 PM
mooredan's Avatar
I have both installed - Clarke tank and Unabiker rad guards.
I did run into an installation problem that was easily corrected.
https://www.kawasakiforums.com/m_194..._5/key_/tm.htm
Old Nov 18, 2007 | 04:59 PM
Sid Post's Avatar
Did you need to do anything for the Clarke tank specifically? I don't understand the top flange modification because mine bolted up on top just fine. The hole in the bottom flange is a modification I need to make which I guess is specific to the 2007 model KLX-250S due to some manufacturing change between the 2006 and 2007 models.
Thanks!
Sid
Old Nov 19, 2007 | 07:56 PM
mooredan's Avatar
I don't believe that my radiator guard installation issues were due to the Clarke tank at all. As you state, and my guess is too, that some of the 2007 radiators have a slightly different flange on them compared to the 2006 models.
I may be alone here again, as far as I know, no one else has confirmed the radiator guard installation issue that I encountered.
Angier
Aug 20, 2014 10:21 PM
mudjunkie
Jan 22, 2008 10:34 PM
kawi boy
Nov 28, 2007 08:19 AM
MaverickAus
Oct 26, 2007 05:57 AM
Thunderchild
Oct 18, 2007 09:28 AM
