Choke won't stay open
Old Sep 22, 2006 | 04:18 AM
markturbo's Avatar
Default Choke won't stay open
When I pull the choke open to start the bike it no longer stays open by itself, I have to hold it open by hand. It started doing this the day after I brought it home from the dealer. It doen't matter if the bike is warm, or if it's a cold start. Is there some sort of friction adjustment screw to adjust so it will stay open until you push it closed?
Thanks
Old Sep 22, 2006 | 04:23 AM
Bad Bear's Avatar
Default RE: Choke won't stay open
Yes there is either a nut around the shaft or the black rubber boot around it just tighten it up a bit till it stays in...... I have not looked at mine yet but that is how most of them work
Old Sep 22, 2006 | 04:31 AM
markturbo's Avatar
Thanks, I did pull the rubber boot back and I saw the nut that the choke shaft goes thru, it's so tight in there though I couldn't get anything on it lol. I'll have the carb out soon to do the mods so I'll do it then.
Old Sep 22, 2006 | 04:57 AM
bryantjt's Avatar
The choke on mine moves freely and then you can pull it farther and it will latch I guess I would call it. For the most part though, after the carb mods you just need to pull the choke out a bit to start it initially and then just push it back in after it starts.
aloehr
Aug 11, 2011 08:29 PM
Captain Kuhle
Jul 24, 2011 05:41 PM
shadymonukah
ZZR 600
Mar 6, 2009 02:42 PM
tbspyder
May 3, 2007 08:24 PM
preemo_21
Oct 5, 2006 09:18 PM
