Chain Tension Tool
I haven't seen anyone post something like this before and I don't remember mentioning it. When I first got my bike I would always have to get the manual out to see what the specs were for chain tension slack. In case your wondering it's 50-60 mm (2007 model) measured at the surface of the swingarm just behind the chain slider with the bike on sidestand.
Anyway, considering I do have a leaky mind, I could never remember this and I figured there had to be a better way. Well, there is. I used a little piece of flat bar and hacksawed two marks for minimum(50mm) and maximum (60mm). Looks like this: http://inlinethumb15.webshots.com/13...600x600Q85.jpg So now I don't have to remember any numbers or try finding the measuring tape. Just gotta remember where I put the tool at. :) All I gotta do is this: http://inlinethumb48.webshots.com/14...600x600Q85.jpg Nice and easy. Just thought I'd share. It's not patented or nothing so feel free to make your own. Doesn't need to be flat bar...even an old used paint stick cut off will suffice. ;) |
nifty. i always thought that chain slack was measured by the distance up/down but never thought to measure off the swing arm.
It is also one of those things that once you've done it a thousand or so times you can just tell, or you can feel a loose chain when riding and know to fix it as soon as you stop.
I like it, hey if you do patent it, can I get a free one? :)
Originally Posted by linkin5
(Post 457571)
Originally Posted by deej
(Post 457578)
Good idear there relic ! I'd lose track of it too. Paint it a bright color so you can see it better.
Dan |
That is a great idea.... ill have to make one for the KLX and KLR.
Originally Posted by Klxrelic
(Post 457562)
Anyway, considering I do have a leaky mind, I could never remember this and I figured there had to be a better way. Well, there is. I used a little piece of flat bar and hacksawed two marks for minimum(50mm) and maximum (60mm). Looks like this: http://inlinethumb15.webshots.com/13...600x600Q85.jpg So now I don't have to remember any numbers or try finding the measuring tape. Just gotta remember where I put the tool at. :) All I gotta do is this: http://inlinethumb48.webshots.com/14...600x600Q85.jpg Nice and easy. Just thought I'd share. It's not patented or nothing so feel free to make your own. Doesn't need to be flat bar...even an old used paint stick cut off will suffice. ;) Are they saying I can measure from either place? Wouldn't the allowable "play" for top and bottom be different? Measuring from the bottom is a pain in the butt. I'm probably over thinking this. |
Originally Posted by kilodelta
(Post 472072)
"measure the space between the chain and the swingarm upper surface at the rear of the chain slipper. It should be 35 ~ 45 mm".
In the original post it is 50mm-60mm from the top of the swingarm at the rear of the chain slipper. That is correct on the 06-07.
