CHAIN TENSION ADJUSTMENT
Old Jun 15, 2008 | 10:44 PM
07 KLXER's Avatar
Default CHAIN TENSION ADJUSTMENT
When adjusting the chain tension on the KLX i have done the following.
Can anyone confirm this is correct
I set the chain tension to spec 50-60mm of play as per manual.
I set the adjuster cams to the same number on both sidesand push the wheel inhard against them and tighten axle nut.
If i have the adjuster cams on the same number does this mean the wheel is straight and running true?
Seems to me it looks right but just wanted to check
Cheers
Old Jun 15, 2008 | 11:36 PM
Default RE: CHAIN TENSION ADJUSTMENT
You got it. Oh and welcome in case I didn't get a chance to say it.
Klxrelic
May 16, 2012 05:42 AM
stiguy
KLR250
Jun 10, 2008 05:42 AM
dadalus23
Ninja 500R
May 12, 2008 08:21 PM
06klx250
May 20, 2007 04:14 AM
cwgoff
Aug 30, 2006 05:46 PM
