caution with the ebay levers
Ordered a set of these levers on ebay. From china, should have know better. Very nice product, but the fit sucks. The are very loose and rattle around. Just not wanting anyone else to get burned.
CNC Brake Clutch Levers For Kawasaki NINJA 250R 2008 2009 20102011 | eBay
that is exactly what it needs but will have to be very thin. Less than a 1/16" maybe 1/8" if I am lucky. Will see what the mom and pop hardware store has, if not Vato Depo.
46092-1117 '06 EX250
46092-1175 '06 KLX250S
numbers from my parts fiche.
If thickness is an issue on the perch. You may get a teflon washer from your hardware store for less sticktion and to fill the gap as mentioned above.
As I posted above above the newer model klx and ninja's have the same levers. Not talking about the 06 - 07
The BB numbers are still different: Remember that the initial numbers are a part classification so to speak. The second set of numbers will correspond to the actual part number for your ride.
Here is what I found on BB. The '08 started the second generation of the lil ninja's, so all of the second gen levers are the same number from what I have seen so far. $13.00 is outrageous for a lever though.
'09 KlX 250 bb number: 826808
'09 EX 250 (new gen) bb number : 2403020
