caution with the ebay levers
Old 04-20-2012, 11:23 PM
cegusman's Avatar
Default caution with the ebay levers
Ordered a set of these levers on ebay. From china, should have know better. Very nice product, but the fit sucks. The are very loose and rattle around. Just not wanting anyone else to get burned.
CNC Brake Clutch Levers For Kawasaki NINJA 250R 2008 2009 20102011 | eBay
Old 04-20-2012, 11:57 PM
the link says for the ninja twofiddy new generation.
Old 04-21-2012, 12:00 AM
cegusman's Avatar
they are the same levers as the 09-12 klx250. Pull up the ninja and klx on bike bandit for replacement levers. They are the same oem part number.
Old 04-21-2012, 12:07 AM
wildcard's Avatar
is the problem with the fit on the perches ? Maybe a small washer to take up the slack ?
Old 04-21-2012, 12:17 AM
cegusman's Avatar
that is exactly what it needs but will have to be very thin. Less than a 1/16" maybe 1/8" if I am lucky. Will see what the mom and pop hardware store has, if not Vato Depo.
Old 04-21-2012, 12:28 AM
46092-1117 '06 EX250
46092-1175 '06 KLX250S
numbers from my parts fiche.
If thickness is an issue on the perch. You may get a teflon washer from your hardware store for less sticktion and to fill the gap as mentioned above.
Old 04-21-2012, 12:37 AM
cegusman's Avatar
As I posted above above the newer model klx and ninja's have the same levers. Not talking about the 06 - 07
Old 04-21-2012, 12:38 AM
46092-0028 '08 EX250 lever
apparently, the numbers are different and are causing you concern in your fitment.
Old 04-21-2012, 01:33 AM
wildcard's Avatar
Just looked at the fische on BB and the levers are the same and the perches are the same.
09 klx and 09 ninja250.
Old 04-21-2012, 02:54 AM
The BB numbers are still different: Remember that the initial numbers are a part classification so to speak. The second set of numbers will correspond to the actual part number for your ride.
Here is what I found on BB. The '08 started the second generation of the lil ninja's, so all of the second gen levers are the same number from what I have seen so far. $13.00 is outrageous for a lever though.
'09 KlX 250 bb number: 826808
'09 EX 250 (new gen) bb number : 2403020
Quick Reply: caution with the ebay levers
