carb question
carb question
I noticed on the carb mod posts the picture show a brass spacer , my kit did not come with one,
how important is it, should i look for something to replace it.
RE: carb question
I'm assuming your 'kit' is non-OEM like Dynojet or something similar, so someone who has used the Dynojet can chime-in.
All I know is that the N1TC needle comes with a spacer and clip....not sure about the Dynojet or other aftermarket kits. Might they have the spacer built into the needle already?
ORIGINAL: redbrd
RE: carb question
My dynojet kit came with two washers that were used instead of the spacer. Put the washers where the diagram shows the spacer. I think this is correct but can't remember if I guessed or read it somewhere. It worked fine that way though.
DirtSurfer
03-25-2018 07:26 AM
