Need help tuning 2009 250sf
Old 08-04-2018, 08:13 PM
Rhumphress's Avatar
Default Need help tuning 2009 250sf
At sea level..
No lid on air box
klx 300 header and tail..ie full.. no butt plug
was sold a Factory Pro jet kit.
came with what I'm lead to be live are keihin jets
#38 pilot
#115#118#120#122#125#128 main jet
a needle with grooves and clips..
so I tried the #38 pilot #125 main and clip in second groove..
started right up idles great..
runs like crap.. mid to full open it's surging and bogs like it's just struggling..
not sure which way to go....
I know I Should've got the DJ kit.. but there has to be a set up with this Factory Pro that will get me where I need to be..
Old 08-04-2018, 10:51 PM
Helps to know your general location - elevation. At around 1000 ft the main used was a Kiehin 128 by my brother and I used a 125 along with a Dial-A-Jet. We used the information from D.Pippin's site. I forget if I used a 38 or 40 pilot, but it works pretty good.
Old 08-04-2018, 11:16 PM
Rhumphress's Avatar
00.00'
I'm at sea level...
Old 08-04-2018, 11:53 PM
RageHardIntoTheBendies's Avatar
You are way, way lean on the main jet for a lidless setup.
I'm at sea level.
#40 pilot
#152 kehin main
n1-TC needle (that's the Kawasaki one) on 1st notch
DJ kit doesn't come with big enough main jet for lidless either, only the needle is really useful.
Old 08-04-2018, 11:55 PM
Rhumphress's Avatar
Awesome... that is the kind of info I'm talking about..lol..
I just need some direction..
my dr350 was so much easier to tune in..lol
Old 08-05-2018, 12:02 AM
Thats with a stock header, two bro's slip-on and a K&N filter, should be ballpark for your setup tho I'd imagine.
Old 08-05-2018, 12:59 AM
Klxster's Avatar
Rhumphress, see your PM.. We can't proceed until I have a "bearing" on that needle you want to run..
Old 08-05-2018, 04:21 PM
Rhumphress's Avatar
Thanks guys..
jet will be ordered monday..
have to get the washers for the needle.. that kit I purchased is missing the washers..
Old 08-19-2018, 03:12 PM
Rhumphress's Avatar
Put in the k152 jet and set the factory pro
needle in 3 groove and the bike came alive..
no more fiddling around ....
time to ride this fun little bike.
Old 08-19-2018, 06:47 PM
RaceGass's Avatar
I'm at sea level.
#40 pilot
#152 kehin main
the dj kit 2206 has a selection of main jets that worked with both the stock klx displacement and for the big bore 350 kit running no airbox lid running kit #78 from b&b.
Quick Reply: Need help tuning 2009 250sf
