buying and installing a gps power source
Old Apr 24, 2014 | 08:59 PM
klx-vn's Avatar
The gps is a "All Terrain 4.3 Inch Motorcycle GPS Navigation System "Rage"". I don't plan on powering anything else.
edit - the gps showed up earlier than expected. sorry for the lowres pic
the removable housing has an electrical contact area. 2 seperate power cords are provided: a cigarette lighter plug-in and one with bare leads.
So it looks like the one with bare leads can go directly to the battery... or be wired in somewhere to have a key cut-off/on?
Attached Thumbnails buying and installing a gps power source-all_terrain_4_3_inch_rdto7rtx.jpg.thumb_400x400.jpg   buying and installing a gps power source-img_20140424_161732.jpg
Illking's Avatar
Originally Posted by durielk
but I hate always having to turn the GPS back on after each time you stop on the trail or hit the starter....
good point.
Old Apr 25, 2014 | 12:19 PM
dpippin's Avatar
Originally Posted by klx-vn
i need to install a power source for my gps... anything recommended/preferred for the klx?
I installed a fused line directly from the battery with a two prong SAE connection for the GPS.
Once I turn on the GPS it's always on until I manually turn it off.
And that's OK because the GPS draws very little amperage from the battery. You could leave it on all day and it won't run the battery down.
Check the link below for photos.
Tips & Tricks
On the same page you can see where I installed a BMW style 12 volt outlet for heated clothing etc.
This is connected directly to the battery (fused) so it can be used to plug in a battery charger.
It's mounted where the front turn signal used to connect as I have the turn signals mounted on the brush guards.
Doug
Old Apr 25, 2014 | 03:15 PM
Doug,
Your website ^ is very helpful. Best screen removal instructions I've seen.
Old Apr 25, 2014 | 03:30 PM
durielk's Avatar
Now if you could just find a trail!
Old Apr 25, 2014 | 05:51 PM
klx-vn's Avatar
Thanks for the info.
Robot Check Robot Check
Attached Thumbnails buying and installing a gps power source-41vwhgzeyjl._sx466_.jpg
Old Apr 25, 2014 | 07:27 PM
with this
SpongeBob
Mar 15, 2015 11:21 PM
Borg
Apr 30, 2012 08:23 PM
jeepphamilee
Feb 20, 2007 03:07 AM
Marty
May 1, 2006 11:50 PM
eztalking
Sep 23, 2005 11:11 PM
