Brand New Bike Dried Up Coolant?
1 Attachment(s)
Brand new 2012 klx 250s
Noticed on the bottom of the right side radiator dried up coolant, along with on the filler cap. Crusty gray green residue. Then under the water pump there is a small hole with the same residue. Now I noticed this today with around 180 miles on the bike. And have not seen or smelled any coolant yet. Just now cleaned it up to see if it comes back Im hoping maybe the radiator overfilled and ran down the front, and down the hoses. Maybe from dealer prep? Then dried up. Now there is no reason to have any coolant leaking out of that pump drain hole correct. It would only leak if the seal or something was bad? So far overflow container looks to have the same amount of coolant in it from when I got the bike but I think I will make a line on it to see if it changes too much from hot to cold. Thankfully I have 1 year warranty on the bike Attachment 11718 Also saw one of the bolts on the cylinder the coolant hose connects to had a drip of what looked like oil on it, but if its a coolant passageway bolt I would think if anything it would have dried up coolant on it. Maybe its just oil from something else? Really need to look over everything on this bike I guess Hopefully these arent future problems:mad: |
If I'm reading you correctly, this is a brand new bike, right? Not sure I'd get too excited at the moment about the presence of fluid residue immediately. Clean off those spots of residue, and then keep a close eye on them to see if any more fluids show up there.
yes new bike
im just hoping since there was residue on the bottom of one radiator, and up on the filler cap maybe it somehow leaked all down the side of the bike along the hoses and just wasnt cleaned up just thought it was strange to have residue all over those parts, I even remember seeing the white spots on the lower frame tube the day I took it home just never looked under the bike until today when I put it up on a stand. so maybe it did that on the ride home, or was there when they first prepped it before I got it had no miles on the odo so I know its new |
went on 25 mile ride
no residue or signs of coolant on the radiator, cap or that drain hole but I will keep an eye on those areas the next few more rides I would think if it was the pump seals it would leak as long as the engine is running like ive seen on cars with failing water pumps |
oil clear?(turns milky when seal goes in my experiance rads fill the case up) idk if the pump and main case are conected on this bike or not
only like 260 miles on the bike, its brand new
but im planning on changing the oil tomorrow, leaving in the filter so I will be able to get a good look at the oil, in the window it looks dark if that helps and I know nothing about how the pump ties into the bike, if the water could have a chance to get into the engine |
dark is better than a milky grey-green so its most likely not the seal per my experience
Originally Posted by MikeW
(Post 482149)
but im planning on changing the oil tomorrow, leaving in the filter so I will be able to get a good look at the oil, in the window it looks dark if that helps and I know nothing about how the pump ties into the bike, if the water could have a chance to get into the engine Hopefully you've already found and followed the MotoMan breakin process. Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power I did, and it made the bike a totally different animal. Probably too late to do it now, as you've passed the mileage where it would make any difference at this point. Gotta start that with a fresh engine! |
(Post 482149)
but im planning on changing the oil tomorrow, leaving in the filter |
If you want to check for small drips of coolant out that hole, take a small balled up piece of paper towel and tape it over the hole. Ride and then inspect the paper towel.
