bill's front brake line
Old May 12, 2007 | 04:09 AM
lcpl0331's Avatar
Default bill's front brake line
Got the steel braided front brake line from Bill yesterday and put it on tonight. i noticed a huge difference. it is definately worth it. i couldn't be happier with how much better the front brake works now.the fit is perfect.this is astaight up remove replace job. getting it bled right is a bit of a chore but it's soooo worth it.
Old May 12, 2007 | 12:23 PM
2k1w=no$'s Avatar
Default RE: bill's front brake line
Does it just replace the rubber line, or is it replacing the hard line in the front and bottom of the fork and running up the top?
Old May 12, 2007 | 12:49 PM
JB1's Avatar
JB1
[sm=ttiwwp.gif]
Old May 12, 2007 | 01:57 PM
bryantjt's Avatar
It is a full replacement from caliper to master cylinder. Bake posted some pics a few posts down.
Old May 12, 2007 | 02:14 PM
lcpl0331's Avatar
it replaces the entire line. unbolt the top unbolt the bottom and remove the stock line. we bolted up the bottom filled the line until there was fluid coming out the top banjo bolt then bolted the top banjo on and bled the line until there was no air in the resevoir. it took a while to figure this out but once we did it went smoothly.
here they are.
Old May 13, 2007 | 02:17 AM
DirtSurfer's Avatar
Hmmm, there seems to be one thing missing from this writeup....
HOW did you end up bleeding the line? What was the procedure? Do you recommend this for the novice home garage mechanic?
Any details you can share would be great.
Thanks!!!
Old May 13, 2007 | 03:27 AM
KLXer's Avatar
Pump & hold lever--crack valve--release lever---repeat (& I do mean repeat, alot)
Old May 13, 2007 | 03:43 AM
DirtSurfer's Avatar
Thanks.Quick follow up question.... What do you mean by "crack valve" ?
Old May 13, 2007 | 03:47 AM
AgoosSS's Avatar
If you search the Internet there a quite a few different tricks for brake bleeding. I struggled with mine as well. What has worked for mewith a new line is to push the fluid up from the bottom with a large syringe until everything is full. Then do the normal break bleed method. I use one of those short hoses with a check valve in the middle.A $50.00 hand vacuum pump looks like it would make the job real easy.
Old May 13, 2007 | 03:51 AM
DirtSurfer's Avatar
ok, gotcha... Thats the visualI was missing.
Thanks!!
