Bikes
Old Apr 13, 2006 | 04:27 AM
KAWASAKIspeed's Avatar
Default Bikes
I am new here and would like see everyone's bikes please. and if you can remember list your mods. that you have done heres mine.
http://s15.photobucket.com/albums/a3...t=IMG_0045.jpg
http://s15.photobucket.com/albums/a3...t=IMG_0047.jpg
Iwill get the list ready and post it tommorrow or somthing, looking forward to seeing your bikes.
Old Apr 13, 2006 | 04:51 AM
sdunne's Avatar
Default RE: Bikes
My list of Mods and click on the camera ICON under my avatar to go to my photo album.
-MOTION PRO VORTEX THROTTLE
-VINYL BLACK NUMBER PLATE/PLASTIC BLACK PAINT
-XGX SKULL GRAFFIX KIT
-REMOVED SIGNAL LIGHTS(NOT REQUIRED IN NORTH CACKILACKY)
-BELL ULTRA LIGHT MOUNTAIN BIKE MIRRORS
-PRO TAPER CR HIGH BARS
-PRO GRIP THIN GRIPS
-SEAL SAVER DOGHNUTS
-13T AFAM C/S SPROCKET
-47T SUNSTAR REAR SPROCKET
-108L DID MOTOCROSS CHAIN NON-O RING
-ACERBIS TAIL LIGHT/ LICENSE PLATE LIGHT ASSEM.
-DYNO JET STAGE 2 300R KIT
-MUZZY FULL EXHAUST
-REMOVED SNORKLE, DRILLED 6 HALF INCH HOLE IN AIR BOX COVER ABOVE FILTER
-UNI 2 STAGE FILTER
-HACKED OFF REAR FENDER FRAME FROM HELMET LOCK BACK
-HACKED OFF HELMET LOCK
-TOOK OFF UPPER CHAIN GUARD AND HACKED MOUNTS
-N-STYLE NUMBER SETS
-REMOVED GROCERY RACK
-CYCRA STEALTH MX HAND GUARDS
-REMOVED AIR INJECTION SYSTEM
-REMOVED FAN
-VENTED CRANK CASE W/ 3/8 INCH DRILL
-WORKS CONNECTION SKID PLATE
-KENDA TRACKMASTER 2 TIRES
-ASV F1 CLUTCH PERCH
-MOTION PRO FORK PUSH BUTTON BREATHER VALVES
-REMOVED KICK STAND KILL SWITCH AND HACKED WIRE MOUNTS
-UFO BLACK FRONT FENDER
COMING SOON!
-FINALLY MOUNT MY IMS TANK(first one to have it last one to mount it)
-IMS FOOT PEGS
-.438 KG FORK SPRINGS
-5.8 KG SHOCK SPRING
I dont know what Im going to do with my self besides ride after everything is done. Im debateing a mikuni pumper carb but Im not sure if it will help that much. And I dont wan't the 300 kit because of AMA rules.
Old Apr 13, 2006 | 06:25 AM
Default RE: Bikes
Mods so far:
[ul][*] Renthal bar & grips[*] MSR Hawkins handguards[*] IMS 3.2g tank[*] stock fan removed, replaced with pair of smaller, lighter (required for IMS tank to fit)[*] smog / air removed
[/ul]
Mods soon to be:
[ul][*] Standard carb / airbox / stock pipe mods
[ul][*] 125 jet[*] N1TC needle + clip + collar, clip in slot 2 from top of needle[*] replace stock snorkel with high flow snorkel[*] enlarge airbox crankcase vent to 3/8"[*] drill first baffle of stock pipe 1/2"
[/ul][*] Kenda 270 tires (stock tires are pretty warn at just over 1000 miles)
[/ul]
I had a 49 tooth rear sprocket, but I reversed that. Too short for me on the road.
Edit: fix image link
Old Apr 13, 2006 | 07:31 PM
Default RE: Bikes
Click on my camera icon to the left under my name. Mods? Hmmmm not much yet,
13 tooth up front
Front fender extensions
Pelican case (thanks to Todd)
On order
Acerbis dual sport handguards with built in turn signals (thanks to Gravy)
rear tail light and flush mount rear turn signals
Dreaming about
A bigger exhaust
Jetting
45 rear sprocket
Old Apr 13, 2006 | 07:48 PM
bmwhd's Avatar
Default RE: Bikes
Um...A bunch of stuff done already. Can't remember it all now ;-)
Old Apr 14, 2006 | 01:01 AM
gouref's Avatar
Default RE: Bikes
ORIGINAL: sdunne
Want kind of mods did you need to make for the Vortex throttle? I did not think that the vortex would work with a push/pull carb.
Fred
Old Apr 14, 2006 | 01:39 AM
sdunne's Avatar
Default RE: Bikes
Our carb is actualy not a push pull carb it just has a follower cable which actualy doesn't do much. The motion pro vortex throttle goes on pretty easy with the oem cable. all you have to do is remove the follower cable from the carb pull off the stock unit make a small adjustment to your controls and throw on the vortex, which is a 1/8th turn throttle which is more for enduro and MX than our 1/4th turn stock throttle.
whitehulk
800, 800 Classic & 800 Drifter
Jan 7, 2006 06:48 AM
Mr. Toad
Ninja 250R
Sep 27, 2005 06:41 PM
78 elcaminoss
Sep 23, 2005 05:20 PM
Nugget210
Jul 8, 2005 07:54 AM
ABruinForLife
Jul 5, 2005 04:03 PM
