Bikemaster turn signal connector issue
Old Feb 25, 2010 | 02:59 AM
BP88's Avatar
Default Bikemaster turn signal connector issue
I ordered some Bikemaster turn signals online for my bike. The connectors on the Bikemaster turn signals are too big to fit in the bike's wiring harness. Is there a way to manipulate the Bikemaster connector to fit into the smaller wiring harness connector without having to buy a new, smaller connector? I'm bad with electronics so any help is appreciated... thanks.
Old Feb 25, 2010 | 04:02 AM
WestOzKLX's Avatar
Just plat the bare wires and add a drop of solder. Add some shrink wrap before you join them, then shrink it down when you're done.
Old Feb 25, 2010 | 04:17 AM
neilaction's Avatar
I had the same issue with my after market indicators.
Soldering is OK and gives you the most reliable joint.
No good if you want to be able to quickly remove the indicators.
With the large bullet connectors you may be able to crimp them up with a set of pliers. That what i did.
There is a split in the metal.
Squeeze one side of the split inwards and the squeeze the other side over it.
Be gentle and do it bit by bit until they will squeeze up inside the smaller female end.
The female end can also be opened up a bit.
Old Feb 25, 2010 | 04:42 AM
MaverickAus's Avatar
After not being able to buy the small connectors anywhere, I cut them off and crimped on the large connectors to fit the ones that came with the blinkers
Old Feb 25, 2010 | 04:57 AM
neilaction's Avatar
Here ya go.
This is a large male connector squeezed up to fit in the small female connector.
mmmm large male in small female
Old Feb 25, 2010 | 01:08 PM
BP88's Avatar
That's what I was doing earlier with some crimpers but I stopped because I thought I might ruin the connector. Thanks!
Old Feb 25, 2010 | 02:37 PM
I would have cut both wires and crimped on new flat spade clips. Never had a problem.
vegaas315
Classic Sportbikes
May 15, 2011 04:13 AM
corder13
Dec 3, 2010 06:39 PM
kory_martin25
Jun 26, 2009 09:35 PM
WestCoast4Life
May 4, 2008 09:47 PM
Crasher986
Jul 8, 2007 10:07 PM
