Bike won't start on it's own!!!
RE: Bike won't start on it's own!!!
ORIGINAL: doitinthewoods
gap is good
gap is good
you say it cranks very fast?
i dont have much bike exp but i do work on a lot of cars
on a car when it cranks fast and empty its a lack of compresion
typically a broken timing belt
i know this is to simple and easy to over look but is the plug in and sealed?
all of the compression would go right out that hole if not
Bike turns over very fast won't start you can smell the gas, ran great beforeI put it away for the winter the float bowl has been drained spark plug has been changed battery is 100% I've had it checked Bike will start when boosted from my blazer then runs fine shut it off won't start again. Talked with the Yamaha dealer (closest to me) he said it sounds like the stator, I've brought my bike to the kawi dealer Thurs they adjusted my valves said way to tight for the bike to start on it's own on Fri dealer called me up and said the bike woul'nt start againg and they want to keep the bike till Mon, They said they tryed the cdi and that's great now there thinking is a ground cause theres frame paint where it's grounded it's been like that for 3,200 miles!!! And there wanting to charge me for all this tinkering around Thoughts??? I'm still thinking the stator is bad
Kawi called, said my bike is fixed they say it was the engine ground they took care of it with the warranty still charged for the valve adjustment they did'nt ask me to performI figured it's for they best since I still have four years to deal with them. Thanks for the help y'all
DirtyHustle
03-23-2014 02:34 PM
METALMAN4247
12-29-2012 10:57 AM
lefecious
04-15-2007 05:21 AM
