bike stalling
Old Mar 7, 2015 | 01:15 PM
durielk's Avatar
I think you have a fuel issue. I would drain & clean the tank, install fuel filter, drain the carb bowl and clean the carb.
Or, someone took the carb apart and the slide diaphram is messed up.
Old Mar 7, 2015 | 09:03 PM
Tin's Avatar
Tin
Okay so already cleaned carb drained fuel tank I found I started the bike in first I can switch gears without stalling and turn off. start in neutral and switch without stalling like starting in gear fixed it. left it overnight and same problem till i started in first again any ideas. didn't know these bikes had a fuel filter
Old Mar 7, 2015 | 09:47 PM
durielk's Avatar
Well, this may be more involved.
Since you did the easy stuff... ha. I am thinking there is a switch for the neutral position somewhere, maybe in the tranny or in the side cover (?) that lets the ignition/computer know it's position. This may be out of adj? When all this is happening, do you notice if the neutral light comes on or flashes?
If you have bad fuel from the gas stations in your area??? If you do, you should add one, a lot easier than pulling the carb.
Old Mar 8, 2015 | 12:18 AM
Tin's Avatar
Tin
Yeah right I'll look at getting a little In line filter then I'll go for a ride this arvo and check out the light and what exactly happens. Might research the transmission a bit before I start pulling that apart
Old Mar 8, 2015 | 12:35 AM
ol'klx-er's Avatar
Perhaps check all the connections relating to the clutch, sidestand and neutral switches. Easier than tearing into the transmission.
Old Mar 8, 2015 | 01:37 PM
durielk's Avatar
Tin, my post was more of a suggestion, I have no experience with this component. Perhaps someone that has been into the motor case has some input or definitive information on this idea.
Old Mar 9, 2015 | 04:47 AM
Tin's Avatar
Tin
Just an update on the stalling issue. Doesn't seem to do It anymore since all valves been adjusted and car by cleaned only done it that once and not again went for a ride bout 2 hrs yesterday arvo and was fine sounded better after valves done and has a bit more go in it so might leave the stalling problem see If it happens again thanks for everyone's help
Jonajones
800, 800 Classic & 800 Drifter
Apr 8, 2016 04:49 PM
revtor
Apr 12, 2011 02:17 AM
zaft
Jun 29, 2008 02:43 PM
123FU
May 28, 2008 01:37 PM
Wolf Lover
Aug 25, 2006 06:45 AM
