Big Bore Bliss
Old Mar 25, 2012 | 03:22 PM
jhoffy22's Avatar
Originally Posted by GaryC
What NEW ignition is that???
Did i miss something this winter????
If I remember right, there has been a custom CDI put out on the market for the 06-07 which allows you to program your own maps!
Old Mar 25, 2012 | 03:43 PM
ahnh666's Avatar
put about 7,000 miles in 7 months...almost all highway miles...even 500 miles of full throttle riding in a day..and same the 2nd day...can a 331 or 351 still do this?..anybody seen any long term reviews on these big bore.kit klx?...
Old Mar 25, 2012 | 04:03 PM
wildcard's Avatar
I think Larry's got quite a number of miles on his 351. And Tiger has over 6k on his IIRC.
either way i can't wait for my Cycle Pro 331. Should be here tomorrow !
Old Mar 25, 2012 | 04:08 PM
https://www.kawasakiforums.com/forum...26/#post466274
Old Mar 25, 2012 | 04:54 PM
Subasaki's Avatar
Why not the 351?! Either way, good job.
the whole "wet sleeve" thing I guess
Old Mar 25, 2012 | 06:08 PM
2veedubs's Avatar
Not so much the wet sleeve thing. Just seems to me that without porting the head, buying cams and carb that the 351 is more of a low to mid rpm motor. The project 351sm thread shows good results with all of the above. I did not want to go that far. I also put the intake cam to stock specs, as it is known that the big bore does not like advance on the cam. I left the ex cam ret. In place as that would have required acr retiming and I wanted to see how it ran like that. I will ride a while to get a feel for the bike and then put the ex cam to stock for comparison. I look forward to the dyno charts that ZrexRich has showing stock/351,fmf,stock carb/351,fmf,BillB carb.
Old Mar 26, 2012 | 03:07 AM
CousinLarry's Avatar
I don't even know how many miles I have on my 351, but it's a lot. hahaa.. My speedo cable snapped three times so a lot of miles not logged. I have like 3700 on the ticker now, got the 351 at 1k. I wouldn't be surprised if actual milage is more like 7k, I was unemployed for two years and rode almost daily with friends. That whole time about 95% was un-metered. I have no idea, but I don't hesitate to take the bike anywhere. It's very reliable so far!
After Bill changed from those pesky copper head gaskets, that is
Old Mar 26, 2012 | 03:30 AM
2veedubs's Avatar
Glad to hear of your trouble free miles Larry. I am a big fan of your videos, thanks for sharing them. On your carb did you drill your slide? Or did your kit have the spring? I am thinking of putting the stock spring back and drilling the slide 7/64. Your throttle response seems good in your videos so I thought I would ask. I have the DJ kit for the 09 and the response is not great, not bad but not great. It seams a CV carb would benefit more from a larger opening than a lighter spring. The spring also helps close the slide so weaker seems like a bad idea.
Old Mar 28, 2012 | 01:31 AM
2veedubs's Avatar
The 331 is running like a champ. Has anyone tried drilling the slide instead of using the DJ spring. Many threads on CV tuning say drilling the slide makes it much more responsive. I will get to it sometime this week. I would like a little more response without changing carbs.
Old Mar 28, 2012 | 02:08 AM
kansas-klx's Avatar
I drilled my carb slide 7/64" soon after I got my machine and it works fine. Never had any Dynojet stuff with my CV, just stock. Since recent conversion to BB351 am still fiddling around with jetting but that's just tweaking for best mpg one adjustment at a time. No major issues for me with the BB351 setup w/CV carb at all.
Note: I ride mostly on KS highway and dirt roads, no hard trail riding, etc so your results may vary if you're a little more extreme.
