Best plus size gas tank for 2006-2007 KLX 250s?
Old Mar 14, 2016 | 07:58 PM
CraigT's Avatar
I have the Acerbis on my '07 and it's great. I had two issues at first but none since. The petcock was gummed up so the seller sent a replacement. The brackets were wrong and the seller would not help because the tank is not listed for our bike. I called Acerbis directly and they sent the correct brackets which still have to be bent but work just fine.
Old Apr 10, 2016 | 03:18 AM
Ruggybuggy's Avatar
Originally Posted by EMS_0525
Nope. Unbolt stock tank, bolt in Clarke. My range is decreased anyway because of the 351 kit. Ive never actually ran it to reserve since the bigger tank and jug. Since i got the KLR the KLX is my woods bike.
EMS_0525, are you running the TM36-68 carb? Just wondering if it will work with the Clarke tank.
Old Apr 10, 2016 | 07:24 PM
dpippin's Avatar
I'm using a TM36-68 with a Clarke tank
I'm only using the pull cable on the TM36-68 so it doesn't interfere with the fuel tank
Rode for years with a pull cable only with no problem and the TM36-68 has a hefty return spring.
Some installation info here Mikuni TM 36-68 Pumper Carb
Doug
Old Apr 10, 2016 | 08:29 PM
Ruggybuggy's Avatar
Hey Doug, thanks for the reply. Do you think the Clarke would interfere with the carbs's return cable if you used it? I was going to go with the natural white so I could see the fuel level but I think it's a little pointless because you would only be seeing the top part of the tank.
Dave
Old Apr 10, 2016 | 08:44 PM
anciano's Avatar
Originally Posted by klxnoobie
Acerbis tank will be a drop in fit for the 06 - 07 years 09 and up their's a little gap between the seat tank and frame. Not that it matters to most they just want gas. If you want maximum fuel available Acerbis is the way to go. If you don't need the range or you don't mind carrying fuel bottles or a flatpack gas can and you like the looks of the shrouds IMS makes a good tank. Which is what I have on my 12 model. I had the same dilemma as you and in the end the stock look just kinda won out. That and the fact that their's not another bike part sitting on a shelf in my garage.
Are you saying that the Acerbis tank with application for the 06-07 models will also fit 09s? It seems like the selection of tanks for the 09 is pretty limited from my searches. Not sure why manufacturers seem to overlook the 09s.
Old Apr 10, 2016 | 09:48 PM
dpippin's Avatar
Dave
I looked at clearance of the throttle actuator to the Clarke tank and I have ample clearance there with the actuator cut off as indicated on my web site.
If you want the push cable you'd have to experiment with the carb mounted and tank installed.
With just the pull cable everything works just fine
If you insist on the push cable you may run the risk of the throttle binding if the throttle actuator interferes with the tank
That could be a dangerous situation where removing the upper portion of the throttle wheel and push cable eliminates that possibility and it all functions well without the push cable.
I also had a new cable made from Motion Pro (see blueprint on web site mentioned in previous post) as the stock cable was a very tight situation. Again safer to have a little play in the cable to ensure it doesn't bind.
Doug
Old Apr 10, 2016 | 10:06 PM
Ruggybuggy's Avatar
Thanks for your reply.
Old Jan 11, 2018 | 09:58 PM
Jeepalaska's Avatar
Default 09 gas tank
This is quite an old thread, I see people say that there is a write up somewhere on making the 3.7 tank fit the 09 but for the life of me I cannot find it any help would be great. I contacted Accerbis and they flat out said it does not fit so would love to see a write up if someone made it work.
Old Jan 12, 2018 | 06:41 AM
RaceGass's Avatar
Look up 'Acerbis 3.7 tank reviews?' By kylrmtncruzr.
The 3.7 does fit but modifications to the two side panels and the choke **** have to be performed first.
gthomas17
Sep 30, 2015 06:53 AM
BuellerWI
Sep 26, 2014 01:46 PM
gerrynolan
Jul 25, 2009 09:57 PM
JonnyD
Jun 5, 2008 02:45 AM
tennisman
Jan 2, 2008 02:53 AM
