Best ez Clutch lever
Old Jul 13, 2013 | 01:43 PM
kennysupermoto's Avatar
Default Best ez Clutch lever
Im having a hard time with the stock clutch. Over 50km pr day ride to work in traffic, very hard to clutch up with 3 fingers. so much pain. Whats the best ez clutch for a klx250? Thanks
Old Jul 13, 2013 | 02:52 PM
You may have something else going on there. Even with the OEM lever cut off to make a shorty, mine is an easy 3-finger effort. I've gone to great lengths to insure the cable runs in the smoothest, least sharp bend manner. Then I use a cable lube that has teflon in it. I have one of those cable lubers that clamps on the lever end...cable disconnected from lever...and has rubber seals with a little feed hole for an aerosol spray can tip to press into that feed hole. I wrap a small rag around the lower cable end and just pump lube into the cable lubing tool until I get a decent stream coming out at the bottom. It lubes the cable while also flushing out grit and other particles. Makes for a smooth cable pull. Also make sure your lever isn't pinched up at the handlebar perch. Lube the lever pivot with antiseize.
Dragon
Jun 7, 2007 02:40 AM
2k1w=no$
May 30, 2007 08:50 PM
CarpeDiem
Mar 3, 2007 11:16 AM
Bujin2000
Sep 9, 2006 08:05 AM
grafhky52
Jun 13, 2006 12:10 AM
