Beefier Binders
Old Aug 28, 2007 | 01:38 PM
tremor38's Avatar
Default Beefier Binders
If you are satisfied with the stock brakes on your KLX, don't waste your time reading this.
If you would like a very noticeable improvement in stopping power,read-on.
I was at the dealer yesterday picking-up new boots and two new side covers, so I can switch to my old, scratched-up ones when I tour with saddle bags..
Anyway, I noticed a wave rotor kit for the the D-tracker/KLX250 hanging on his wall that costs over $400.00. We started discussing various alternatives, when I suddenly remembered that his D-tracker has much better stopping power than mine and asked him why. He told me that he installed a rotor, master cylinder and teflon brake line from a KX250 and said it was a direct bolt-on. The improvement in stopping power is definitely noticeable. He said all of the parts -if bought new- would cost about $250.00 which is not cheap but is a decent savings when compared to most aftermarket kits.
Just thought I would share that.... 'Thatis all'
Old Aug 28, 2007 | 04:08 PM
bryantjt's Avatar
Default RE: Beefier Binders
Good info. I'm sure it would be beneficial to anyone running street or street biased tires.[sm=smiley20.gif]
Old Aug 28, 2007 | 04:10 PM
would they beas reliable and long lasting as the stock stuff?
Old Aug 28, 2007 | 04:49 PM
mustang's Avatar
Can you give us anymore specifics? For example, what model years that will work, and whether it's the 2-stroke KX250 or the 4-stroke KX250F.
You said he installed a rotor, master cylinder, and a teflon brake line.Are the stock caliper and pads re-used?
Old Aug 29, 2007 | 01:46 PM
tremor38's Avatar
ORIGINAL: mustang
You said he installed a rotor, master cylinder, and a Teflon brake line.Are the stock caliper and pads re-used?
He is very thorough and attentive to small details, so if he changed anything other than the parts I mentioned he would have said so. The KX rotor is the same diameter and thickness as the one on the KLX, so the caliper and pads don't need to be changed. The KX master cylinder has a larger working area on its piston and the rotor is physically different somehow, but my Japanese isn't technical enough to pick-up what he said. It is the KX250(2-stroke) not the 250F. As for the model years, I will ask him.
As for the question about reliability, I can't tell you for sure, but all I knowis that he has had no issues with them on the semi-pro motard circuit here in Japan... and they get punished.
Old Aug 30, 2007 | 12:43 AM
Truckman's Avatar
guys look up the various year parts on bike bandit.com . I did and most parts from the 88- 00 kx 250/500 are bolt on parts for our klx bikes.I'm also going to add the brake kit from a kx500 to my klx which i already specced out but have not had the dough to buy as i've been laid up with a broken foot recently.........but yeah....all those parts should bolt right on.
Old Aug 30, 2007 | 01:35 AM
cool change's Avatar
What did you do to your foot truckman. Hopefully you didn't crash the kawi. When you get better we have to do some riding...So I don't get accused of thread jacking I'll add that the brake upgrade looks good. LOL
Old Aug 31, 2007 | 03:23 AM
Sid Post's Avatar
Has anybody done this brake upgrade? How would you describe the performance of this setup versus the stock one? Is it $250 well spent?
Thanks!
