battery craped
First of all, you should never put'crapes' inside your battery. No whipped cream or strawberries either! Just add water.
[8D]
Sorry, I don't know of a good gell cell without doing some in-depth research. I believe the stock battery is rated at either 6 or 6.5Ah, so a gell cell of similar rating anddimensions should do the trick. Please post results if you find one.
[8D]Sorry, I don't know of a good gell cell without doing some in-depth research. I believe the stock battery is rated at either 6 or 6.5Ah, so a gell cell of similar rating anddimensions should do the trick. Please post results if you find one.
was out riding in my backyard hit some jumps shut it off, cranked slow then next start died like a shorted cell. started up the next day charging ok was only good for one start up. ill check out the agm thanks
