Bags and subframe
Old 03-26-2012, 01:18 PM
stephenmarklay's Avatar
I can kind of see how the foot peg mounts would provide support. It would be interesting to see how much support they provide by taking out the other bolts and leaving just the foot pegs. I wonder if it stays up and requires a bit for force to bend down or sags a bit under its weight. I may just have to order one to and find out.
Old 03-26-2012, 01:21 PM
Originally Posted by DYNOBOB
Here's my take on the rear subframe. Kawasaki designed it w/ rear footpegs for a passenger so surely they have confidence it can handle at least 100 pounds distributed between the seat and footpegs. Imagine the product liability of a failure w/ a passenger on the back. I realize there have been failures but it seems like there must have been some other factors in play...
If the KLX had remained my primary bike I would have eventually owned the Happy Trail system that uses the Givi E21 cases, neat looking setup.
No doubt at all that you are correct. The problem is once you get weight behind that area its not a sub frame as much as two post sticking out. They are cantilevered and great for holding the small bits on the bike but dubious otherwise.
The Dirt-bagz panniers do as you suggest and would be a pretty safe pannier set-up at the expense of carrying a passenger.
rbarchi
08-22-2010 06:04 PM
fullmonty03
03-21-2009 12:10 PM
Kupo42
Ninja ZX-9R
03-08-2008 08:56 PM
Shadetree
10-10-2007 01:46 AM
fireroad
07-06-2007 05:37 AM
Quick Reply: Bags and subframe
