anyone install a kickstarter?...battery dead today
Hmmmm, don't you getlikean initial roll, then itlocks-up? Those lowergears -causing the engine to spin muchfaster- probably spinthe ACR fast enough toclose the exhaust valve.Otherwise the high compession alone shouldn't be a factor....interesting...to me that is[8D]
ORIGINAL: MaverickAus
You can push start it, or roll start it but with 11 to 1 compression 3rd gear is preferable otherwise the rear wheel just locks, even on the road with road tyres. I had it lock all the way down a steep cement drive in 2nd trying to roll start mine, left a liquorice strap down my sisters drive lol
ORIGINAL: Finger Mullet
Update, after numerous calls to semi local dealers, I just need to preload the starter spring to generate the centrifugal force to disengage the ratchet gear........ So I'm offline to re-remove the right side and attempt this along with a couple Bass for sanity purposes.
In any case, your answer will be educational for me[8D]
Cool!
I'd definitely like to tear one apart and see how it ticks. Looking at the drawing, I just cant see how centrifugal force would bring the ratchet apart, unless the splines are helical. I must be missing something.
Yup, problem fixed, preloading the spring solved everything.
ORIGINAL: tremor38
Are you suresure centrifugal force is the issue here?
ORIGINAL: tremor38
ORIGINAL: tremor38
you could just put a charger cable onto your bike. and then just get a charger and plug it into the wall a cheaper way atil works. just a thought.
ORIGINAL: tremor38
Very cool man.. Here' s to NEVER having to use it!!!![sm=partyparty.gif]
ORIGINAL: DirtSurfer
Nice job Finger mullet, I think your the first to have added the kickstart!!
ORIGINAL: tremor38
