any one have a picture of...
after lookin thru the "mod day" post and studying up a bit i was wondering if
any one has a picture of what you drill in the carb w/ 7/64th bit? i havent really played around with that side of the carb yet... i just got all my gets and the nt1c needle, clip, coller, 128,125 #40 and am not really sure where to put the clip... 2nd ring from the needle end or 2nd ring from the short end?? very minimal mods... cc, k&n, drilled stock exhaust
thanks for posting
thanks for posting
oh and one more thing... the fule air screw. I bought one that fits the kx250 because the kid behind the counter said it would fit... i dont belive anything he says but it was the only one left so i figured i could at least try it and if it doesnt work take it back. beats waiting 4 WEEKS FOR PARTS![sm=smiley35.gif]
ORIGINAL: pie4foou
In the case of the KLX, Kawasaki chose to limit the carb opening by drilling two holes near the top of the slide. This has the effect of reducing the vacuum that pulls the slide open. The quick fix is to fill the holes with epoxy.
And something else to keep in mind when putting the needle and plastic collar back in is to make sure the feet on the plastic do not cover the hole!!! someone mentioned thata while ago and it stuck with me when i did mine..very good thought!..you'll see what I mean if you look when putting it back together.
hahaha (epoxy)... and yes he was a pimply squeaky voiced one. the same kid that "tried" to order my parts A MONTH AGO... but my card was declined and the two numbers i gave him to call me at "didn't work" yeah right! so instead of ordering the $20 worth of parts for me and having me pay when i pick it up he'd rather me wait a week and call and ask why my parts arnt in yet... He must have thought it was fun to put my order in a day before Christmas. that little [sm=smiley35.gif]. alright calm down, calm down, take a breather.
anyway referring to the mod day page. When he says
"...turned it over and quickly opened the slide housing, drilled the slide breather hole 7/64ths and tossed the slide in hot water to keep the diaphragm from expanding. I got the new needle ready, with the clip on the second notch with the collar."
does he really mean cold water to keep it from expanding? or do you really use hot water... (last i checked hot=expand cold=contract)
oh and about the air screw... DOH! i'm an idiot and so is he![sm=icon_stickpoke.gif] I went on ebay and found the one i got... its from white bros and it fits any and all FCR carbs... so i guess i'm S.O.L. going to return it tomorrow, know where i can order one online... (done wasting money at my local shop)
From Bike Point:
http://www.bikepoint.com.au/portal/a...opDefault.aspx
"In standard from the KLX is heavily restricted, so here's the hot set up to make the bike perform in the manner it was supposed to. First of all pull the carburettor slide out and fill the two holes drilled in the top with epoxy resin or similar and smooth off so that it doesn't snag in the body. Alternatively fit a new slide without holes, Kawasaki part #161261382. Remove the airbox snorkel and the spark arrestor in the end of the exhaust. Finally, go up three teeth on the rear sprocket. The result is an extra seven PS and more power everywhere. Sorted!"
