Any melted B&B stickers? Normal or I ran too hot?
Old Oct 19, 2016 | 06:07 PM
I think you have it.
There's one wire at the factory thermal switch at the bottom of the right radiator. You can test the fan's operation by grounding. IIRC, remove the wire, then use a jumper to connect the switch's exposed connector to ground. The fan should turn on. So, now cut the stock wire somewhere and install a SPDT (on-on) switch. One switch position goes to ground (that's 'new wire #3') and makes the fan turn on manually. The other switch position is normal, stock operation.
Yes, there's a bit of extra wire but it's easy to keep tidy and put a switch in an accessible spot.
dan888
Oct 17, 2011 04:03 AM
brownie2
Aug 28, 2010 06:34 AM
ttakata73
Jul 2, 2010 04:22 AM
aszrael1266
Jun 19, 2007 03:37 AM
kwninja88
Aug 22, 2006 12:59 PM
