any exhaust gut experts here?
Old Jun 6, 2022 | 01:34 PM
wozzz's Avatar
Default any exhaust gut experts here?
Hello. make you can help me out with my KLX 250 stock muffler. I had to cut a hole into it to take out a piece that was loose and clanking inside like hell. closed it back again by welding. now I miss the noise it had before since the piece that I extracted was this (damper?) pierced pipe with a sleeve around it. so im considering opening it up again and welding the piece back in, since it is in good shape. only the attachment points rusted and that's whay it fell off.
My question is whether that piece goes attached to the pipe coming into the muffler from the engine side or wether it goes welded to the pipe coming out of it toward the tail opening. I'm attaching a picture of the part I don't know where to weld. I need to know in order to decide where Im cutting open the muffler to drop and weld it
THX!
this is the damper sleeve tat goes somewhere inside the muffler. where??
stock exhaust for reference
Old Jun 7, 2022 | 03:04 PM
tooter's Avatar
THX!
While I've done exhaust work, I've never cut open a stock muffler.
You could simply get another one. Here's one for $92 including shipping on ebay.
KLX250 muffler
Old Jun 7, 2022 | 04:12 PM
wozzz's Avatar
KLX250 muffler
the problem is i’m in brazil and shipping that here has a ridiculous cost. But thanks for your answer!
Old Jun 9, 2022 | 06:59 PM
wozzz's Avatar
Default Solved
So to reply to my own post for the record and for reference to future muffler gutters I finally opened up the muff. There is nothing in there xcept for two metal reinforcements. Tue baffle or whatever it is calles goes at the tip of the tube coming from the bike, where the muffler starts. Pics for ref
The baffle is on the left
Baffle welded in place
stichin’ it up
now the bike sounds the way I like it. powerful bul no loud high frequencies
Old Jun 11, 2022 | 11:08 PM
tooter's Avatar
stichin’ it up
Thanks for sharing such a useful piece of information!
I'm happy you resolved the problem.
I've never seen the insides of a stock KLS muffler before, and I'm pretty sure no one else has either.
Have you taken any pictures of the insides of the rear section?
If not, can you describe what is inside that section? How long is the tiny exit tube? Is it perforated?
Old Jun 12, 2022 | 02:06 PM
wozzz's Avatar
the rear section is a closed unit, did not get inside but it has a horn like tube coming into it at the center, about same diameter as exhaust pipe. that leads to a finned twister, not sure if directly or via some kind of baffle there too and out through the rear. from the bach ally can see is the finned thing inside. the exit tube is not tiny. it is about same diameter of input tube on this particular model
Tacoma660
Jul 22, 2020 09:50 PM
Ruggybuggy
Sep 11, 2015 11:06 AM
chainslack
Feb 28, 2013 06:37 PM
stro
Jun 18, 2012 11:08 PM
JETHRO980
Feb 20, 2007 11:36 PM
