Anti-backfire screen removal
Old Feb 14, 2009 | 08:39 PM
TrailCruiser's Avatar
Default Anti-backfire screen removal
Quite a few here have mentioned they removed the anti-backfire screen in the airbox. To those that have, how did you remove it -- it is molded into the plastic air filter holder? Looks like you could just cut around the edges with a utility knife but it would likely leave a messy edge of wire stubs.
Also, the stock air filter is already foam, any data on whether one of the aftermarket foam filters, such as the Uni, actually help flow in any measurable way?
Old Feb 14, 2009 | 08:45 PM
Exactly then smooth out with a sander or grinder. Lots of good aftermarket air filters out there, I like the k&n with metal screen (for backfire) and lifetime warranty....but any brand is probably just as good and way better than stock.
Old Feb 14, 2009 | 09:03 PM
GreenMonsta's Avatar
I cut the screen then used a dremel with a sanding drum to smooth it out. I'm sure a fine round file would work it would just be a bit more tedious.
Old Feb 14, 2009 | 11:33 PM
WestOzKLX's Avatar
Did a read through some time ago. This is for an 07 with the KLX300R high flow airboot, but you'll get the idea.
https://www.kawasakiforums.com/forum...ckfire+screeen
Old Feb 15, 2009 | 12:54 AM
lcpl0331's Avatar
stuff a rag or something similar in the air boot so that none of the filings get into the carb and then clean out the air box really good when your done sanding.
Old Feb 15, 2009 | 04:49 AM
MaverickAus's Avatar
How is it better than stock? I'm running the stock and 3 years later all is good
Old Feb 15, 2009 | 07:09 AM
Well I haven't done a scientific analysis on it but I bet my k&n has less resistance (pressure drop) across the filter surface than the stock setup......more air flow = good.
Old Feb 15, 2009 | 07:24 AM
tremor38's Avatar
Why do it on the bike? The screen is removable. I had it in and out several times. One of the nuts isn't the easiest to get to, but if I can do it with only one fully functional hand, anybody can.
Old Feb 15, 2009 | 03:03 PM
SPKGO's Avatar
whats the point of this mod?
I'm assuming its for better air flow. but its got to be hardly noticeable, if at all.
Old Feb 15, 2009 | 11:06 PM
tremor38's Avatar
There's no before/after dyno data, so it's anybody's best guess.
