Another brake issue
Old Jan 27, 2015 | 12:00 AM
RockabillSlapMatt's Avatar
Default Another brake issue
My rear brake was spongy and progressively becoming worse. Pads? Rotor?
Today on the ride home it went from wouldn't stop well, to wouldn't stop at all!! Did I snap a line? what the heck happened. I get home and this is what I see.
Yes that's a screw missing, and prior to this photo, the one on top was tightened, as it too, was about to fall off.
Why is it a big deal? You can ride with just one screw, right? Wrong. This is what happens when only the top screw is tightened
The pedal actuation moves the master cylinder instead of pushing in the plunger to compress the brake fluid. I.E NO STOPPING POWER
Kind of an odd thing to happen, because the 351 vibrates more? I've never touched those screws since owning the bike. I suggest everyone go out and check them out, could be a scary disaster down the road. (yes I realized the rear brake wasn't working when it started raining and I was slowing down to a stop sign...)
Old Jan 27, 2015 | 02:16 PM
A loosening rear brake master cylinder isn't something common, but it does have bolts, so it's not impossible. A new bolt, a little Loctite, and you're good. Better that than what neonarc is trying to diagnose on his brake system.
Old Jan 27, 2015 | 02:27 PM
neonarc's Avatar
Definitely better than my issue. I wish I had it that easy jaja
Old Jan 27, 2015 | 02:52 PM
Quite fortunate indeed, after as much headache as he's gone through I'd just replace the master cylinder and the line
Old Jan 27, 2015 | 07:20 PM
neonarc's Avatar
I'm one step away from doing that jaja. I'm scared I'll change the MC and the problem will still be there, then I'll have to get a new caliper jajaja. Oh well, bright side, it's a good excuse to upgrade.
Old Jan 27, 2015 | 09:17 PM
ol'klx-er's Avatar
Upgrading the line to braided stainless is worth doing even if the stock line isn't suspect.
Arickrock
Oct 17, 2013 01:31 AM
caliklx
Nov 27, 2011 01:22 PM
dngrrngr
Mar 14, 2009 06:53 PM
94Ninja250
Mar 27, 2008 12:06 PM
ntloser
Oct 23, 2006 02:07 PM
