Adjusting rear suspension preload
Old May 19, 2014 | 04:37 PM
Burnt09's Avatar
Default Adjusting rear suspension preload
Is it OK to adjust the rear suspension preload using a drift and hammer on the adjustment and lock nuts, or must I take the shock and spring off as directed by the owners manual?
Thanks
Old May 19, 2014 | 04:59 PM
ahnh666's Avatar
yup...that works better then trying to use the special wrench...tap the top ring loose...tap to tighten or loosen the bottom ring...lock in the top ring after you are done...pretty simple..
Old May 19, 2014 | 06:54 PM
Brewster's Avatar
The adjustment rings will move easier if the bike is on a stand.
Ride on
Brewster
Old May 20, 2014 | 12:21 AM
cegusman's Avatar
What is the correct sag for these bikes? Will it make a difference if s or sf model?
Old May 22, 2014 | 03:46 PM
JaMan's Avatar
Try this link
KLX SAG ADJUSTMENTS
jhoffy22
Apr 2, 2012 04:02 PM
jimntr
Feb 11, 2010 02:50 PM
preemo_21
Ninja ZX-7R
Apr 13, 2008 03:28 AM
dcorlando
Nov 20, 2006 03:15 AM
espacef1fan
Aug 13, 2006 05:51 AM
