adjusting front forks
Old Jul 17, 2010 | 07:19 PM
hogzilla's Avatar
Default adjusting front forks
Ok help me out on this one. Comes factory 12 clicks out. If I want stiffer front end do I go in or out on the adjustment? Thanks
Old Jul 17, 2010 | 07:30 PM
zomby woof's Avatar
You will want to go in to increase the damping. A stiffer spring, or small spacer at the top of the spring might be what you really want.
Old Jul 17, 2010 | 07:59 PM
hogzilla's Avatar
yeah the front end is really soft. I am going to crank them in to see if that helps any. Thanks
Old Jul 18, 2010 | 03:22 AM
RimBender's Avatar
It'll help slow down the fork but you'll have to click it way in to really notice much, like 2, 3 or 4 out from all the way in, At least that's how mine acts and I'm running thicker than stock fluid.
kawaski used a pretty soft spring but runs the oil level high so the airspring effect kicks in close to bottoming.
If you put a zip tie on your fork leg you may find even though it feels like your blowing through ALL the travel you may be short of the full 11".
Pepe72
Sep 17, 2010 01:45 PM
ScreamingBuckeye
Jul 23, 2010 04:28 AM
open air
Aug 27, 2008 03:58 PM
foggys916
Oct 5, 2007 05:24 PM
06klx250
May 20, 2007 04:14 AM
