Acerbis Tank & Enrichener
Old Dec 1, 2009 | 03:34 PM
Ranger Ron's Avatar
Default Acerbis Tank & Enrichener
When I first put my Acerbis tank on my 2006 I faced the petcock handle to the rear because there was a bit more space there. Removing some material on the **** allowed me to (barely) engage the enrichener past the fuel line.
When my back-ordered fuel pump arrived, I mounted it on the original petcock bracket which made it impossible to reach the petcock handle. In order to use the petcock on the Acerbis tank, I had to turn it around so that the handle faced forward. There wasn't enough room then to operate the enrichener.
I solved that by extending the enrichener shaft with a piece of speedometer cable. It flexes enough to bypass the petcock and is stiff enough to pull and push the enrichener.
I drilled a 1/8" hole in the end of the shortened shaft for the speedo cable and secured it with JB Weld. Now the **** on the end of the cable comes out to about the center of the frame member. It's easy to access with gloves on.
Ron
Old Dec 1, 2009 | 06:48 PM
punkenduro09's Avatar
wow good idea. the choke problem (thank god) isnt that big of a deal if you live in warm weather areas, but where theres snow it must be a pain.
Old Dec 5, 2009 | 07:24 AM
LongmontKLXr's Avatar
excellent (simple) and creative solution.
Old Aug 2, 2017 | 10:41 PM
klasjm's Avatar
I am putting my Acerbis tank on my 2006 I faced the petcock handle to the rear because there was a bit more space there. Is this the correct way? As it seems I will not be able to put the bike on reserve.
Old Aug 3, 2017 | 01:58 PM
klasjm,
Mine is the same direction on an '06 and there is no interference positioning the petcock to reserve with either the stock carb or the TM36-68.
Old Aug 4, 2017 | 12:34 AM
Same here with the stock carb and now with the TM36-68. I think everyone has to face it to the rear.
maninthesea
Nov 28, 2009 12:56 PM
09klx250t9f
Nov 2, 2008 09:13 PM
WestOzKLX
Oct 9, 2008 02:05 AM
Finger Mullet
Jul 30, 2008 09:21 PM
DJFields
Jan 7, 2006 04:04 AM
